i dnt really know lot about cars just owend my first r33 might be a stupid question but as i sayd dnt kno much so
my clutch is gone now im goin to upgrade it to a racin stage 2
ill run about 700hp and is a daily drivin but weekend it drift alot and dragrace
i know they told mi act stage 2 wil do fine but i get these stage 2 6 puk disk or srupng 4 puk disk idk what s the benefit or dowside of these puk or no sprung or srpung 6 or 4 puk so if some1 could help mi or explain to mi whats the downside or benefits between these
https://www.sau.com.au/forums/topic/410509-upgrading-clutch-on-r33/
  • Replies 70
Mr NPC here. haha damn you mat.
For such a high power application you should be looking at some strong twin plate.
is this 700hp at the treads or 700bhp?
Anywho contact NPC (who saw that coming?)
Oi mat, how is the jim berry? I havent seen any posts about it...
I always feel a bit sad when people are buying "stage 2" etc parts
It isn't need for speed, no idea why people market parts like this
Because for 60-70% of people who come from something different, think that is the norm and from a marketing perspective, it works fairly well.
Also remember that 80% of statistics are made up and shouldn't always be taken as gospel but 50% of the time, it's right every time
60% of the time, it works every time?
What kind of cash money are we talking with NPC clutches for something around 400-500bhp? I've just done my HD clutch in the skyline at 220rwkw only 10,000kms old, one day after I got it back from the tuners. Haven't had much luck with cars lately.
ok so ill would need to be looking at nismo or npc 4puk sprong kits ?
material wise ??
im askin cause dnt realy have knowledge in this area
Ring NPC tomorrow on 07 3277 9403 and Doug will be able to talk you through whatever your needs are. They can custom build any clutch to your requirements and as long as you're honest about what you are going to do to it, it will never fail until its old
material wise ??
have you driven a 4puck clutch before? with 400hp the organic might be better for stop/go daily driving
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
