Why billet flywheel?
Are you asking why it's billet or why a billet flywheel is required?
Billet flywheel because of the risk of bursting (not a spelling mistake - burst not bust) the standard cast iron one once you get over certain torque levels. They are like a ticking timebomb. Lots of people run the standard one at power levels over 450whp and nothin happens. Then one day BOOM off comes a leg for some poor chap at the track.
Not to mention the car is also written off because its cut your chassis rail in half.
Not worth the risk for the unknown quantity. I know enough to know that an organic plate isn't going to burst a flywheel and neither is 400hp at the wheels no matter how hard you try. 500hp on the other hand, have seen a few go bang.
Your choice
  • Replies 70
can just imagine a clueless bogan thats managed to strap a to4 turbo on and got over 500hp, a fag in the corner of his mouth and next thing a flywheel comes thru the floor haha.. :woot:
but seriously, that is some scary shit..
Edited by SliverS2
Billet Flywheel is also lighter, and the NPC flywheels have cooling channels that direct some airflow through your clutch. Not sure how effective it is but good idea
kinda wish I'd just gone a twin plate, but I'm happy enough with what I have
I puchased the NPC organic today, it has been stamped on it Exedy UFO52
What would be the difference between the exedy sports tuff clutch rated 280kw and the NPC organic (330kwrated), the material must be the same if it has exedy stamped on it.
Yanks use a "scattershield" or a steel bellhousing to protect drivers at drags. If you buy a Nismo twin plate or similar you get a better flywheel with the package.
Not just for big V8s:
http://jalopnik.com/5502903/video-honda-crx-grenades-entire-nose-in-wild-clutch-explosion
http://jalopnik.com/...lutch-explosion
BUt thats in a Honda and Honda's are for girls dicks.
Had my organic NPC fitted yesterday, is alot better than the exedy,
the gears seems easier to go in too so maybe the old one was dragging or not bled properly, and feels like it pulls harder and very smooth engagement :whistling:
So NPC and my tuner , FTW :P
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
