hey
i have recently cleaned my throttle body on my 2001 M35 stagea, and now it wont idle correctly.
i did the relearning and it still hasnt changed.
now what its doing is when i start the car it revs up to 2000 then down to 1500 then back up to 2000 then rests at 1200 and slowly moves down to 800-900, it only does that when it is hot tho, when cold it just revs to 2000 then sits at 1200.
the other problem is when driving arond 60km and i release the accelerator the revs drop down to 600 and the car engine brakes hard then it jumps back up to 1200-1400, its also using more fuel then usual.
does anyone have any clue what is going wrong?
cheers
https://www.sau.com.au/forums/topic/410519-idle-problem/
What was ur purpose for cleaning it? U've probably removed the sealing stuff that seals the butterfly to the throttle body. U can buy the stuff from somewhere, don't know where but. It will have to come back off to apply it
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6557958
i was doing the rocker cover gasket and spark plugs and noticed it was ugly looking so i sprayed some brake cleaner on a rag and cleaned inside it, after i did it i found a topic saying do not move the butterfly.. :/
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6558019
do the relearning procedure again, it didnt work the first time. you may need to perform the 2 other steps beforehand. then attempt the throttle re-learn procedure. perform that prodecure when the car is engine warm. ie: operating temperature
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6558039
Did you actually notice it do the re-learn? Or just think it hasn't worked?
Its quite distinctive - it revs up, drops slowly past 650 to just above a stall then comes up again (you will feel it stutter). You Rev it up to check the reset, and it should idle 650 +- 50 at normal temprature.
I only ask because it is not easy to nail the reset proceedure, and lots of people have trouble with it. It does work though.
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6558040
ok i did then learning when the car was warm and it didnt nearly stall when i did it however it did return to around 650 and returned there after reving, however once i turned the car off and restarted it, it went back to idle at 900-1000.
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6558048
Tomie throttle coat from justjap approx $70
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6558513
hmmm so sounds like a trip to nissan :S
Nobody in Adelaide has a Cipher cable?
If you do need to go to Nissan, just ask them if they could plug in their Consult and hit the throttle learn button. Should take all of 30 seconds from when they plug it in (plugging it in should take all of 20 seconds)... but they will prob try to charge you for an our's work
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6559099
If your idle does not set between 650-750, the ECU will not learn the new setting.
Another influence on setting the idle correctly can be the PCV valve. This has a hose running from the drivers side bank to the drivers side of the plenum. If you remove the hose from the Plenum and block off the inlet to the plenum you can try to reset the Idle to see if this has any influence.
Good luck.
Cheers
andy
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6559924
Good luck.
Cheers
andy
exactly which hose is this?
and if it resets fine what does that mean?
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6559940
It also won't set if there is an engine fault lamp displayed from my experience. It will learn but as soon as I stopped the engine it would go back to 900 revs.
(unless the throttle was damaged, I had to replace it in the end due to a random limp mode fault in the TPS.)
https://www.sau.com.au/forums/topic/410519-idle-problem/#findComment-6560541
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
