Ok, I haven't posted in a long time... anyone who read my post about "dead ECU" may remember. Now.. here's the thing... I have had this problem since I got the car, and it's driving me bat crap crazy! I now have 2 MT ECUs (thinking that was the problem originally) as well as a second AFM... Also NOT the problem. I have data scanned it with Consult as well as bringing it to a dealer.. no fault codes ever. I also have an AT ECU from the previous owner who got it from a shady shop that told him that was the problem.
Initially, the car would run perfectly then suddenly just die and not start again. Switch ECUs and it would run. now it won't even do that half the time! but still.. no fault codes at all. I even replaced the engine temp sensor for good measure. I've ordered a new fuel filter just in case, because when the car dies, it almost sounds like someone switched off the ignition... Blocked fuel filter? After it dies, the car will not start at all for a while, except occasionally when switching ECUs... this leads me to believe it's NOT a fuel problem, but an electrical one. The other day I washed the car, moving it to a different bay in my car park from where I park it... started and ran fine till I went to drive it back to my spot... dead... switched to AT ECU, and drove fine.
I have a funny feeling its a bad wire somewhere, but as there is literally hundreds of meters of wiring in this car, I'm reluctant to pull the harnesses out and inspect them all. I have recently installed a Apex'i electronic boost gauge, and Apex'i Full auto turbo timer and an HKS electronic boost controller (haven't hooked up the vacuum lines yet) all of which I tapped to the ignition switch for switched power. They all work fine (except the boost controller because the stepper motor is not plugged in yet)
One other strange problem that I found recently, when I changed the bulbs in my left tail light, the dash lights would come on when I pressed the brake pedal! WTF?! then when I wiggled the wires to the bulb in the tail light, the dash lights stopped coming on with the brake pedal again.
I will try to take a video of the problem and maybe one of you will have a clue... I am at my wit's end trying to figure out this problem.. I have never come across a car problem I couldn't figure out until now. I hope someone here can help.
Thanks Mates
https://www.sau.com.au/forums/topic/410539-mysterious-engine-problem/
ok.. a little update.. hopefully it might help figure this weird problem out. I couldn't get the car started with the MT ECU tonight, and with the AT ECU, it's chugged and bogged and stalled like a bee with an itch until it finally settled down into a nice idle. I decided to let it get up to operating temp (almost half way on the gauge) and then switched back to the MT computer... lo and behold, the car fired right up and kept a nice steady idle for at least 10 minutes until I decided to shut it off.
It started no problem on the MT ECU 3 more times through the night while I puttered around doing some other stuff. The point is, it was still hot from running up to temp from the first time... soo.. maybe the cold start valve? or AAC? I'm in Hong Kong, and the temp is about 27C, so I can't see it being too cold...
Anyway, that was my findings for tonight. Thoughts?
OH! I checked the voltage and resistance to the fuel pump with a multimeter, and that came up good, so it's not the pump. I read in the FSM that a clogged Catalytic converter might stall the engine like this... anyone think THAT might be it?
The dash light is easy, u have the wrong bulb in the wrong place as in as in a single element instead of double I've seen it before, in terms of the engine issue have u removed fuel pump? Sometimes there can be an intermittent issue with the wiring degrading. Also have u done compression test ? Low compression engines can be hard to start when hot also. Good luck
Scott
Sounds to me like it's an intermittant bad earth somewhere.
I'd check the harness very closely at the plug for the ECU, and as far along as you can access. It could be a simple case of pulling/twisting the wire into the correct position (out of contact with the chassis or something like that) when you change computers, so it seems like the computer's to blame. Just a thought.
Goodluck.
I think your right TurboMick .. Check all the groundings. ensure there isn't any wires broken around the ecu plug. check to see what voltage you get at the pump during the whole stop - start ignition process. clean the afm and TPS (might not be a direct problem but will help)
do you have any other wirings? Sub/Amp/Capacitor hooked up wrong? Is the apexi boost controller etc all wired correctly?
i highly doubt the ecu alone is to blame.
no sub, amp or cap.. I even yanked the aftermarket alarm and all i's components and fixed the wires it was tapped into to eliminate hat. the TT is brand new and wired correctly, and I know that's not the problem cus the car did this before the Apex'i TT was even there. the fuel pump gets full voltage even when the car refuses to start... but it's nowhere NEAR as loud as my old R32 was when the pump was priming... is this due to the R34 having a plastic tank that has that bizarre shape as opposed to the metal box of the 32?
My mate has agreed to let me swap-borrow parts from his GTT to find my problem. I'm starting with the CAS as many ppl have said that is suspect. any other suggestions if the CAS turns out ok?
ok.. so I cleaned the IAC valve the other night and took it for a test tonight.. ran like a champ even when beating on the loud pedal... no even the slightest hesitation or flutter! now, the Idle set screw is fugged.. some cracker stripped it before I got the car and I could only get the idle down to about 1000 RPM, but I can live with that for now. I also noticed when I took the IAC off, the hose going to the intake was split near the intake end. I taped it up with electrical tape for now... maybe this split in the hose was my problem all along?
Nah. Stock idle will depend on temperature, but will variously sit in the range 650 - 800. You only have to look at the settings in Nistune to see what they are supposed to be for any given motor. They tend to idle high when the IAC is all gummed up (read that as stuck open).
My Neo is a bit like that at the moment (mostly when the weather is cold - I suspect the coolant connection at the IAC is blocked and so it doesn't warm up properly). Bloody annoying. When it was warmer it would idle 150-200rpm lower, which was smoother and less thrashy.
it's been a few days and I've stared and ran the car several times with zero problem... I'm starting to feel like an *** for letting something as simple as an intake leak stump me for so long... but in my defense, the previous owner took the car to a shop and was told it was a bad ECU, so I was working from that trying to hunt down some electrical problem. I'm glad I did in a way tho... there were so many bad wiring hacks and whatnot that couldn't be HELPING the situation!
So now I'm tentatively thinking the problem is finally solved, but time will tell. If there is no issues within a month, I think I can confidently say it's fixed.
Actually, it makes a strange kind of sense now.. I replaced the leaking valve cover gaskets, and that's about when this problem got really bad. I took that hose off to remove the valve covers, it must have split more then? Well, just goes to show, the simple problems can sometimes be the hardest to track downsmiley_dukeitout.gif
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
