Hi guys,
Today i have on offer parts from my er34 gtt.
location of parts central coast , nsw
first up is R/H xenon Headlight
condition - ok mounting tabs good, no bulbs. ( had previous angel eye mod done by old owner, HID cut out when imported.)
price $ 200
willing to ship or pick up
hypergear internal wastegate set for 14psi
Condition - new ( ordered for my old setup as plans have changed no longer need it )
price $ 80 ( thats cheaper then hyper gear)
bride seat rails - only fit R34
L/H - condition - as new fitted to car for 2 days.
price $ 200
R/H - condition - used
price $ 90
stock r34 turbo op6 rear
condition - used appox 150xxx kms on it
price $ 200
kumho KU31
2 x 225/40/18
condition - used - 50% tread left
cost -$50 per tyre
pick up only
kumho KU31
2 x 235/40/18
condition - used - 20% tread left
cost - $40 per tyre
pick up only
Suntek
2 x 225/40/18
condition - used - 40 to 50% tread left
price - $ 40 per tyre
pick up only
Thanks for reading
contract number is 0437800066 ( MSG or call )
or pm me
If Ryan wants that turbo ill grab it off you and bring it up here bludger, if not there is a guy in the Wanted To Buy section chasing one too!
He want highflow,
Come get it then and buy some tyres while you here
He want highflow,
Ryan thinks your a mongrel :P jks
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
