I have a complete R34 GT-T
Auto
Coupe
Factory white
110xxxkm
Located in Adelaide, Pick up or postage is fine.
A few prices to start the tread off but just ask and I will write back asap.
Engine $2000
Complete minus:
Turbo
Coilpacks
Water Temp Sensor
Auto Trans $250
Diff $200
Complete ket set: Ignition, doors, boot, nismo key $200
Wheels $650
Brakes: Calipers, rotors, pads $650
Return flow Genuine HYBRID Intercooler with pipes: $450
Bilstein Suspension $800
Turbo back 3" stainless steel exhaust $700
Passengers guard $150
Drivers or Passengers side mirror $70
Dash cluster $150
Triple Center Gauges in housing $150
Climate Control $100
Dash $100
Bare Shell $800
Wingless boot $150
SOLD / unusable:
Front windscreen
Airbags
Standard steering wheel
Radiator
Headlights
Bonnet
Turbo
Coilpacks
Front Bumper
Rear Bumper
Sideskirts
Headunit
Rear Lights
https://www.sau.com.au/forums/topic/410576-wrecking-r34-turbo-auto-coupe/
do you still have the coin holder and washer bottle? how much if so and postage to NSW
Washer bottle -gone
Coin Holder - Assuming thats in the lower dash part next to your right leg? if so $35 delivered
Pics of intercooler?
post-27843-0-08151100-1349146437_thumb.jpg post-27843-0-63857700-1349146444_thumb.jpg post-27843-0-35612600-1349146452_thumb.jpg post-27843-0-17398900-1349146459_thumb.jpg post-27843-0-61185400-1349146466_thumb.jpg
hey bud you still have the front guard indicators ? if so pm me
Cheers mark
I do, $50 for the pair delivered. They are the clear ones
Edited by JiN_MaN
Hey mate,
Can you PM me a photo of the climate control? And do you also have the double dinn surround for the CD player? I would be interested in that also if you could price/pm photo.
Thanks,
Andrew
Hey mate,
Thanks,
Andrew
Hopefully this covers what your after.
If you would like a more straight on photo I can grab one. I just already had this on the computer.
Climate Control $140 delivered
I dont think I have the surround that your after. Unless you can see it in the picture?
Yeah it's not in the picture but that's okay. How much would you like for the climate control & the frame for holding the climate control + cd player? (I'm not sure what that part is called)
Hi sorry about your car
drivers mirror
both side dash vents
delivered to sydney
cheers
Drivers side mirror (needs a polish) $60 delivered
Dash vents $40 delivered
Guessing your talking about the 2X metal tags that hold it all in place? If so $40 delivered for the metal bits
Hey bud yea ill take the front guard indicators of you. and also how much are you willing to sell the driver side door for ?
Cheers mark
The shell of the door has a ding in it, but all internals are in good working condition.
Price for gear surround? The outer surround, not gear selector.
Also does your 34 have stock fog lights? I'm after the switch.
Fog light Switch $20 delivered
Price for steering wheel and airbag please
Id have to repack it and stitch the center back together. :P
SOLD / unusable:
Front windscreen
Airbags
Radiator
Headlights
Bonnet
Turbo
Coilpacks
Front Bumper
Rear Bumper
Sideskirts
Headunit
Rear Lights
Climate Control
Climate Control / Headunit Metal Holders
Passengers Door Seal
Front Guard Indicators
Edited by JiN_MaN
Hi Matt,
What are the front seats like? I should have tried to grab the ones out the car that I got the engine out of from you a long while back!
cheers
Hey,
They dont have any marks or rips or tears but the drivers seat on the drivers side has the usually bolster wear that has resulted in the padding going a bit soft.
$250 for the pair
matt is the black aluminium trim piece above the drivers door straight? if so how much for it
cheers
Yep its straight. Id have to remove the wind deflectors first
$30
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
