Hey guys I'm doing my first rebuild on a car engine. Done plenty on dirt bikes chainsaws ects.
Here's a run down I'm pretty much just giving my rb25 a freshen up while I replace a bent rod due to a hydrolock.
Reuse standard head (maybe new valve springs)
Arp headbolts
Reuse pistons with new OEM rings
Rb26 rods with arp bolts
Acl race series bearings mains and big ends(reuse rb25 piston pins on 26 rods?)
Now it's all pretty straight forward except bearings as I've never done them before. Is plastigauge good to use? Can I just use it to measure clearances? I don't own a micrometer and would rather get by without one for now. I just need to know how to measure clearances so I know what bearings to order.
BTW - Small country town no "engine builders" around, just a bunch of old blokes stuck in their ways.
Yes it would be easier to get a running 25 shortblock, cheapest I've seen is $700 in the city so add $300 for my travel expenses and we are at a $1000 which is what this freshen is probably gonna cost me! I know what engine I'd rather have.
Here's a quick list of prices off me head
Genuine Nissan gasket set $200
OEM rings $180
Bearings $250
Rb26 rods $75
Arp head studs and rod bolts $300
Does your small town have a hire centre? It would be good to get a micrometer to measure wear on the bores and out of round to see whether you are wasting your time rebuilding or not.
I believe if you are going to replace the rod bolts (good idea) you need to rebore the big ends.
Nothing wrong with plastigauge in my view .....some younger compatriots get sniffy about it but I think ideally you measure and then check with plastigauge if you want.
Hi buddy, you are gonna need to get yourself some mic's before you do anything. The bores need to be checked for round and size, and if they are not within spec, its a rebore and new slugs or a wrecker engine. As for the arp bolts in the rods, the big ends will need to be rechecked for size when you fit them. I personally use plastiguage AND a mic when assembling to double check bearing clearances. Best of luck mate, its a little more involved than most people think
0-25mm Micrometer should only be around $70 - $90 for a pretty good one. I bought a Starret 25-50mm unit a few weeks back for $99.
To check the bore's you really do need a proper bore gauge, and you don't want to go out and buy one of them unless you plan on rebuilding many engines in the future. Would be a costly tool i'm sure.
Really your cheapest option for sure is to buy a second hand engine as been said in many of your other posts.
Buy second hand engine, spend money putting new exhaust studs on it, water pump, timing belt kit etc and put it in.
Yes i understand you want to rebuild your engine, but if your bores are out then your going to have to bore it and get new pistons anyway. Then the snow ball begins....
I know but I can't find any bottom ends in good nic.
Answer this I had about 3 liters of water in my engine when I drowned it as it was siting there in the water. It sat for about a day and I replace oil/water lol. Bearings would be rooted yes? I'm
Considering just pulling the rods and putting the 26 ones I got for $75 in, plus might aswell throw new rings in it so there's $250 all up and then just my time.
Depending on the condition of the engine and what you want it for you could replace the bent rod provided its exactly the same centers length and replace the bearings with the same size the originals were . Being fresh they should work fine and obviously did from the factory . Really a glance at the crank journals and used bearings will tell you if its forked or not , low oil pressure could be another indicater of worn bearings .
I don't consider RBs "weak" from the factory and if you're not asking for much more than std performance fancy bolts and 26 rods won't do a lot for you .
If the engines worn out or damaged by water or the lock it needs a rebuild but if it wasn't and is ok the budget option is to fix whats bent and leave what isn't .
If this is for a Patrol you should be able to use an RB30 short though the conversion takes a bit of time and money .
A .
It is for a patrol mate. Was going the 30det route. But I've spoken to an engineer and he saidiota a bit of work with emmisions ect, he said if I go stock 25det, as in intake exhaust and turbo he will pass it. 2 conrods are bent as the engine won't fully turn over. Bores look fine except from a bit of rust on them, when I mine bit, it's under cover and it gets sprayed with crc frequently and the "rust" wipes off with my finger. When I say 26 rods it's just because I can get a set for $75.
Currently just the block is siting in car with every bolt but removed. I didn't have an engine crane till a couple of days ago. I guess I'll pull it and check the bearings, if there's not rust, (shouldn't be motors full of oil) I'll slap the new rods and rings in, car was running fine until the hydrolock. And bores haven't been marked from the lock
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
