hi all
looking for a stock turbo for an RB25 DET Neo engine
want good condition, no/minimal shaft play
prefer Sydney pick up
hopefully looking to spend ~ $250
let us know what you have
cheers :)
https://www.sau.com.au/forums/topic/410589-wtb-syd-stock-rb25-neo-turbo/
Hard pressed for an OP6 with no shaft play for $250. Might have to up your budget by $100. Even then, most turbos will have shaft movement (max .004" vertically & .010" axial as a general rule, well, with the big ass turbos I work with!!!). You might get lucky...........
Hi Stooge007, I have one sitting around it has only run stock boost and its in good condition. I'm in Sydney as well. Price is $300
Ph: 0414787986
Edited by RedWagon
    • Holy hell! That is absolutely stunning! Great work!!!
