  • Replies 44
Give me a PM if you are selling the stuffed gearbox, I need a new case for my spare, it has a hole in it...
Will do, i was offered 20k cash for my car yesterday.. i may go ahead with that. I can get a work car now and the V will only be a weekender, saves me having to buy a new box and shit. The guys loaded with money anyway.
If you get it all installed, I would be interested to know what you think of the JWT Clutch/Fly and how it compares to the factory Clutch/Fly. I am getting sick of the feel of the factory clutch and the narrow engagement window - I have been thinking about the clutch pedal mods, but haven't got around to doing anything yet.
The downside is I have heard if you replace the factory DMF with a standard single piece flywheel, you get a lot of chatter from the gearbox which can be annoying at low RPM..
Well apparently the car has an excedy twin place clutch in it now, i've never driven a manual v35 with the stock clutch so i can't be too sure if it's legit..
I saw a factory CD009 at UPS last week. It was put aside because 1/2 the box was covered in fluid - suspect cracked case in transit - LOL!
Oh shit.. don't tell me that haha
  • 3 weeks later...
Update:
I have been in touch with Z1 performance in states over the last few weeks ttrying to find a better deal for what i want.
Here it is so far:
CD009 Transmission
Chromoly Pivot Ball
Stainless Steel Clutch Line
Nismo Pilot Bushing
JWT Clutch & Flywheel (tossing up between Nismo or UR flywheel as they supposedly have less chatter under 2000rpm)
Redline 75w90 gl4 gearbox oil + same stuff with gl5 for diff oil.
Z1 performance originally quoted me $1,699 + $775 shipping for just the gearbox alone.
I approached Coz at ConceptZperformance a while back and received no response, got an email back this morning from Coz saying "shit that's expensive i'll do it for $2194 delivered" definitely happy with that.
Definitely pays off searching around for a good deal as i'm very happy with saving $300.
Costing me a total of $3068 total delivered in 3-5 days which is great.
Now i just need the money!
Yeah cool cool he said he does alot of high value shipments to Australia and no one has complained to him yet about any GST or taxes lol so that'd be good if he does that.
Couldn't have picked a shitter time of the year to spend $3000.. around xmas and my mrs is expecting a shit load of presents as they do..
If they specifiy a figure under $1000 on the customs delcaration, you will probably be fine.. but just be aware, Australian Customs has been cracking down on this sort of thing recently.. hopefully they won't estimate the actual cost of the items to be above $1,000 and therefore won't invesitgate.
just wrap up little bunches of coal... your near a mine. it should be easy for you to get.
From what I know, if the declaration to customs states that the item is under $1k, customs duty won't apply.
However, if you do get it shipping insurance and it doesn't arrive, they will only cover what's on the declaration. Is $750.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
