Hi All,
For those who bother doing it, what products do you use for detailing your wheel arches?
The standard cleaning part I just use generic products and brushes, however for the next step I'm currently looking at two products to bring out the shine - '303 Aerospace' and 'Meguiars All Season Cleaner'.
There are up and down sides to both -
303 Aerospace is water based so as soon as it gets wet, its pretty much gone. Approx $25 a bottle. Can also be used on engine bays with fantastic results. For me, the fact that it does not last too long is not an issue my the car is always washed once a week without fail.
All Season Cleaner is a Meguiars product with a great reputation however would have to get this imported from the UK @ approx $100 a bottle.
I'll probably end up trying out both, as they both appear to meet my requirements for one thing or another - but interested in any personal experiences with this.
Thanks.
you could try carpro PERL.
It's pretty cheap, and since you dilute it you get quite alot out of that one bottle.
it's really easy to apply, you just spray it on and let it dry, although for areas like engine bays I tend to use an applicator.
It could be good for doing your wheel arches though since you just spray it on? It's also really cheap.
It's decently durable, but not particularly great, especially if diluted. 303 is probably a bit better. But then again - if you're washing it every week this is a cheap solution and easy to use?
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
