hey guys i bought my skyline a few months ago off someone who didnt know much about the car so ive begun the long process of learning what has been broken/changed and ive recently been playing around with all the loose wiring they have left behind...
i noticed under the steering column theres a long cleer tubing with what looks like a screw with a spring behind it? looks as though its coming from the engine bay somewhere....anybody have any idea what this is? i have a picture included....
also is it hard to remove a turbo timer? i have a greddy full auto timer and it seems when i tried to jump start (noob mistake...know not too now..) it must have fried it because it just turns on now and doesnt do any function lol....
is it a matter of just following cords and taking them out or is it a bit of stuffing about....same for neons? has these installed but they are faulty/turn on and off if u jiggle the cord so bit of a fire risk.....
i better not start on the subwoofer/amplifier wiring in the boot which sparks while your driving lol....
soo while i was waiting for replys i went and took the lower fuse interior off and behind it was a mess but i found another black wire with electrical tape on its end.....and if you follow the wire further up it has another one coming from it plus a little red plastic fuse looking thing? (not a fuse...just look like one) any idea what this could be also?
thanks man if anybody else has any ideas on the black cord please let me know :) i wanna try and remove any un needed wires...
so really i should be able to plug and play with a boost gauge seeing as i have the tube already connected?
I would say possibly an old boost controller.
Hose would be for the pressure source.
If you trace it back it probably goes through the fire wall and connects to a vac source in the engine.
Then the cable would be it power source possibly back in the day when it was connected
Or could be the old boost gauge, vacum for the boost reading and then the wires for maybe the illumination!
Also be careful removing wires. Don't want to start chopping wrong ones.
Edited by cree
True never thought about illumination
My boost gauge never lit up :(
hey guys so i went and read up a bit on boost gauge/controller installation and i went and located where the T peice was in the engine bay....but it seems to be in a unusal spot for a boost gauge as i understand they should be connected off the intake lines
when i found this T peice its attatched to a line coming from a black little box on the top left of the engine bay? is that part of the intake or would this be a boost controller connection? pic below...
unfortunately i didnt take a picture of what the black line was running to on the other side but could this be a gauge or controller ? and what is the black box that the T peice is connecting into ?
sorry if im not explaining it right...just hard to put names to things when your not sure what they are lol..if you guys need a better pic showing the whole side of the engine and where the black line is connection too i could go take another one....
Boost controller and the connection to it. It's receiving the presure from one of the black pipes.
Your clear line going into the cabin is likely connected to the controller also.
After market boost gage had been fitted.
That red thing is a scotch lock and they are the devil. Better off twitching wires together(which I also don't advocate) than using them pieces of crap.
Black box in last pic is sensor for boost pressure for factory gauge.
Edited by t_revz
Its exactly where I have mine hooked up and will be fine!
Plenty of places to hook them up but if the factory gauge uses that line then just use that one.
Let us know how you go with the install
Any trouble just post up in here and I am sure we could all help
ahh sweet thanks alot for that, ill let yous know how i go once i get a gauge....need to work out a good brand to go thats accurate
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
