hey guys i bought my skyline a few months ago off someone who didnt know much about the car so ive begun the long process of learning what has been broken/changed and ive recently been playing around with all the loose wiring they have left behind...
i noticed under the steering column theres a long cleer tubing with what looks like a screw with a spring behind it? looks as though its coming from the engine bay somewhere....anybody have any idea what this is? i have a picture included....
also is it hard to remove a turbo timer? i have a greddy full auto timer and it seems when i tried to jump start (noob mistake...know not too now..) it must have fried it because it just turns on now and doesnt do any function lol....
is it a matter of just following cords and taking them out or is it a bit of stuffing about....same for neons? has these installed but they are faulty/turn on and off if u jiggle the cord so bit of a fire risk.....
i better not start on the subwoofer/amplifier wiring in the boot which sparks while your driving lol....
soo while i was waiting for replys i went and took the lower fuse interior off and behind it was a mess but i found another black wire with electrical tape on its end.....and if you follow the wire further up it has another one coming from it plus a little red plastic fuse looking thing? (not a fuse...just look like one) any idea what this could be also?
thanks man if anybody else has any ideas on the black cord please let me know :) i wanna try and remove any un needed wires...
so really i should be able to plug and play with a boost gauge seeing as i have the tube already connected?
I would say possibly an old boost controller.
Hose would be for the pressure source.
If you trace it back it probably goes through the fire wall and connects to a vac source in the engine.
Then the cable would be it power source possibly back in the day when it was connected
Or could be the old boost gauge, vacum for the boost reading and then the wires for maybe the illumination!
Also be careful removing wires. Don't want to start chopping wrong ones.
Edited by cree
True never thought about illumination
My boost gauge never lit up :(
hey guys so i went and read up a bit on boost gauge/controller installation and i went and located where the T peice was in the engine bay....but it seems to be in a unusal spot for a boost gauge as i understand they should be connected off the intake lines
when i found this T peice its attatched to a line coming from a black little box on the top left of the engine bay? is that part of the intake or would this be a boost controller connection? pic below...
unfortunately i didnt take a picture of what the black line was running to on the other side but could this be a gauge or controller ? and what is the black box that the T peice is connecting into ?
sorry if im not explaining it right...just hard to put names to things when your not sure what they are lol..if you guys need a better pic showing the whole side of the engine and where the black line is connection too i could go take another one....
Boost controller and the connection to it. It's receiving the presure from one of the black pipes.
Your clear line going into the cabin is likely connected to the controller also.
After market boost gage had been fitted.
  On 02/10/2012 at 4:39 AM, Razon said:
That red thing is a scotch lock and they are the devil. Better off twitching wires together(which I also don't advocate) than using them pieces of crap.
Black box in last pic is sensor for boost pressure for factory gauge.
Edited by t_revz
Its exactly where I have mine hooked up and will be fine!
Plenty of places to hook them up but if the factory gauge uses that line then just use that one.
Let us know how you go with the install
Any trouble just post up in here and I am sure we could all help
ahh sweet thanks alot for that, ill let yous know how i go once i get a gauge....need to work out a good brand to go thats accurate
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
