  • Replies 262
Hows 8.30am from Gungahlin ? It's just over an hour.
See you at 8.15am at that servo
Will have to wait in line as I expect a few hundred Skylines in the SnS
Edit: Could even meet up at one of the rest stops on Lake George if others are comming.
https://www.sau.com.au/forums/topic/410670-sau-nats/page/8/#findComment-6620445
On the drive to work this morning my front right wheel arch was squeeking.
Now to try find the cause before nats :(
Mine's done this (and is doing again). I believe first time it was a bush wearing out...second time it was the rod you use to hold the bonnet up (CONSIDER THIS!!! If the rubber on the end is worn, it can sit in such a way that it rubs on something causing a squeak). This time it's either this again, or my flimsy front bar mounting/broken headlight mounts. Meh.
https://www.sau.com.au/forums/topic/410670-sau-nats/page/8/#findComment-6620704
Saturday. Unfortunately I wanted to watch the track day, but f**k knows why it's held on Friday....I'd have thought track day and airport runs would've been entirely on the weekend....
Oh well, I've got the SAU dinner too :D
https://www.sau.com.au/forums/topic/410670-sau-nats/page/8/#findComment-6621060
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
