  • Replies 262
Should have seen Shepparton last year, every corner you turned there was another mad GTR or Skyline of some type coming towards you or waiting at the lights.... we took over! :D
Should be awesome in Goulburn then as they only have 3 corners as the town is that small :P
https://www.sau.com.au/forums/topic/410670-sau-nats/page/3/#findComment-6563124
God i would love to come... However unless someone is willing to push the GTR there it isn't going anywhere... Bottom end rebuild and fuel system has been completed however it's still missing the entire head... sigh 5 months without it is getting to me *twitch*
https://www.sau.com.au/forums/topic/410670-sau-nats/page/3/#findComment-6564856
Yeah i might see if verms is taking the Stagea and come up... If not ill pop up on the bike. There is still a slim chance ill be able to take the GTR but i doubt it.... If worse comes to worse ill steal the missus Yaris!! hardcore i know...
https://www.sau.com.au/forums/topic/410670-sau-nats/page/3/#findComment-6565072
take the yaris for an airport run ^ The speed trap number would be OVER 9000
HEY HEY, 80KW and 141 NM of torque... it has the goods to take the day! Lookout JUN, and RH9... the Yaris is coming....
https://www.sau.com.au/forums/topic/410670-sau-nats/page/3/#findComment-6565108
It looks like the GTR might be done in time *crosses fingers* the engine is built it's missing an oil pump and then its done. If so it will be there. But it will still be the driving in stage (under 4000 RPM) sooooo show and shine it might have to be. whole new engine will be interesting : |
https://www.sau.com.au/forums/topic/410670-sau-nats/page/3/#findComment-6573720
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
