Hi all,
For sale is my 1992 R32 GTR that I purchased back in 2003 with 72,000km's on the clock. The vehicle had one Australian owner prior to buying it, and it is now up to 110,000km.
The Good
- Racepace Stage 1 RB26DETT (oil gallery modifications, head rebuilt with new guides, shims etc, forged pistons, R33 GTR crankshaft, sump baffles etc)
- Tomei Poncams (260 in/ex)
- HKS camgears
- Tomei twin entry fuel rail
- 2L surge tank in the boot with Bosch 044 fuel pump, braided lines to the fuel rail
- HKS twin plate clutch (with 50% meat remaining)
- HKS lightened flywheel
- Sard 800cc injectors
- Garrett T04z (0.86) on X-speed high mount manifold with Tial 44mm external wastegate
- Trust/Greddy PE-ii drag exhaust
- Trust/Greddy aluminium radiator
- Trust/Greddy dual entry drag intercooler
- Splitfire coil packs
- HKS Twin Power ignition amplifier
- Autronic SM4 ECU
- Blitz ZZ-R coilovers
- Whiteline front and rear sway bars, all bushes front to back have been replaced with Whiteline
- V-spec Brembo 4 pot callipers on the front with DBA 4000 slotted discs
- R34 GTR wheels with new (90% tread) Federal tyres
The interior of the car is very clean and in remarkable condition for its age, with no dash bubbles and no broken aircon vents. The car has an R33 GTR drivers seat, with normal wear and tear but no rips.
The Bad
- Snapped key stuck in drivers side door lock
- Gunmetal grey front bar and no grill (do have a carbon fibre grill in box, brand new, that will go with the car)
- Tachometer stops working occasionally on the instrument cluster
The Ugly
- 10cm spot of rust on the roof at the top of the drivers side A pillar.
- Dent in passenger side door
- Touched up scrape just behind the rear drivers side door
Summary
Overall the car is in A1 mechanical condition, with all parts above being brand new (excluding the clutch and sway bars which were previously on the car) and installed in the last 5000kms. All mechanical work was done by Autotech Services in Hume, ACT and it has a conservative tune on it currently making 380kw at all four wheels (Autotech have a dyno dynamics 4wd dyno). The car drives straight and I really cannot stress enough that mechanically this car is brilliant, anyone that drives it will be impressed.
The body of the car however does require some TLC - a few thousand on a decent paint job and getting the surface rust on the roof removed is all it would take to make this car absolutely mint.
Why am I selling? I have owned this car for almost 10 years now and interests/priorities have changed over the years. I was intending to fix the body up, but need to purchase a 4WD ute and have run out of garage space. I also only drive the car once a fortnight for a 50km round trip just to keep it running.
The car is located in Canberra and registered with no outstanding defects and is not listed as a write off on any systems. I am asking for $12,000 which I believe is a fair price given the work that has gone into it, and that it is basically brand new mechanically. Will upload pictures tomorrow night.
Best contact for me is through PM on here or via the mobile, 0423 670 289. Due to my job I am often unable to take calls during the day, but will respond after hours.
https://www.sau.com.au/forums/topic/410672-1992-r32-gtr-white-modified-12k/
I have thought about parting it out, but don't have the time or space :)
It would also be a shame imo, as every mechanic who has driven it comments that it is one of the best driving R32's they have come across. It's a brilliant car and if someone picks it up they are getting an absolute bargain - all it then needs is a bit of money put into the body :)
Nik - I think I have a full set of 2nd hand locks with key (except for Ignition barrel). I'll have a look.
I've recently been in Nik's car and it pulls like a runaway.
Bargain buy boys!
No rust under the car. Sorry for the late reply, haven't had a chance to get on here again till now. Car is off the market, missus is now getting rid of hers instead of me getting rid of mine to make the required car space - sorry!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
