Hi all,
For sale is my 1992 R32 GTR that I purchased back in 2003 with 72,000km's on the clock. The vehicle had one Australian owner prior to buying it, and it is now up to 110,000km.
The Good
- Racepace Stage 1 RB26DETT (oil gallery modifications, head rebuilt with new guides, shims etc, forged pistons, R33 GTR crankshaft, sump baffles etc)
- Tomei Poncams (260 in/ex)
- HKS camgears
- Tomei twin entry fuel rail
- 2L surge tank in the boot with Bosch 044 fuel pump, braided lines to the fuel rail
- HKS twin plate clutch (with 50% meat remaining)
- HKS lightened flywheel
- Sard 800cc injectors
- Garrett T04z (0.86) on X-speed high mount manifold with Tial 44mm external wastegate
- Trust/Greddy PE-ii drag exhaust
- Trust/Greddy aluminium radiator
- Trust/Greddy dual entry drag intercooler
- Splitfire coil packs
- HKS Twin Power ignition amplifier
- Autronic SM4 ECU
- Blitz ZZ-R coilovers
- Whiteline front and rear sway bars, all bushes front to back have been replaced with Whiteline
- V-spec Brembo 4 pot callipers on the front with DBA 4000 slotted discs
- R34 GTR wheels with new (90% tread) Federal tyres
The interior of the car is very clean and in remarkable condition for its age, with no dash bubbles and no broken aircon vents. The car has an R33 GTR drivers seat, with normal wear and tear but no rips.
The Bad
- Snapped key stuck in drivers side door lock
- Gunmetal grey front bar and no grill (do have a carbon fibre grill in box, brand new, that will go with the car)
- Tachometer stops working occasionally on the instrument cluster
The Ugly
- 10cm spot of rust on the roof at the top of the drivers side A pillar.
- Dent in passenger side door
- Touched up scrape just behind the rear drivers side door
Summary
Overall the car is in A1 mechanical condition, with all parts above being brand new (excluding the clutch and sway bars which were previously on the car) and installed in the last 5000kms. All mechanical work was done by Autotech Services in Hume, ACT and it has a conservative tune on it currently making 380kw at all four wheels (Autotech have a dyno dynamics 4wd dyno). The car drives straight and I really cannot stress enough that mechanically this car is brilliant, anyone that drives it will be impressed.
The body of the car however does require some TLC - a few thousand on a decent paint job and getting the surface rust on the roof removed is all it would take to make this car absolutely mint.
Why am I selling? I have owned this car for almost 10 years now and interests/priorities have changed over the years. I was intending to fix the body up, but need to purchase a 4WD ute and have run out of garage space. I also only drive the car once a fortnight for a 50km round trip just to keep it running.
The car is located in Canberra and registered with no outstanding defects and is not listed as a write off on any systems. I am asking for $12,000 which I believe is a fair price given the work that has gone into it, and that it is basically brand new mechanically. Will upload pictures tomorrow night.
Best contact for me is through PM on here or via the mobile, 0423 670 289. Due to my job I am often unable to take calls during the day, but will respond after hours.
https://www.sau.com.au/forums/topic/410672-1992-r32-gtr-white-modified-12k/
I have thought about parting it out, but don't have the time or space :)
It would also be a shame imo, as every mechanic who has driven it comments that it is one of the best driving R32's they have come across. It's a brilliant car and if someone picks it up they are getting an absolute bargain - all it then needs is a bit of money put into the body :)
Nik - I think I have a full set of 2nd hand locks with key (except for Ignition barrel). I'll have a look.
I've recently been in Nik's car and it pulls like a runaway.
Bargain buy boys!
No rust under the car. Sorry for the late reply, haven't had a chance to get on here again till now. Car is off the market, missus is now getting rid of hers instead of me getting rid of mine to make the required car space - sorry!
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
