KingManu23 Posted October 3, 2012 Share Posted October 3, 2012 Hi Guys What do you guys recommend for a A/T 2003 V35 coupe. An ECU or a Transgo A/T Shift Performance Kit? I have been told the ECU will cost about $800-$900 fitted and the Transgo Shift Kit will cost $300 (not including labour cost). So performance wise is there a very noticable difference? Regards Manny Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/ Share on other sites More sharing options...
Nightcrawler Posted October 3, 2012 Share Posted October 3, 2012 An ECU really won't do much unless you have serious mods that benefit from 'tuning' the ECU. FYI the shift kit will cost $500+ to fit (incl. service and oil) by a shop - I hope you have included that in your equation. Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6561346 Share on other sites More sharing options...
Jetwreck Posted October 3, 2012 Share Posted October 3, 2012 Uprev gives you control over the gearbox to some extent.... But if you are to supercharge or turbo charge at a later stage you will still need a shift kit done. $500 not including oil is a good price IMO.....just make sure you go to a workshop that has done a couple and knows what there doing....I've seen a heard a couple of horror stories of can do workshops that can't do! And don't let them use dextron for the oil...it will stuff the gearbox. Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6561412 Share on other sites More sharing options...
GED59 Posted October 3, 2012 Share Posted October 3, 2012 definately get the shift kit had my installed a few months back $770 including oil a bit of a rip off but thats Perth. The results are outstanding. Just do it!! Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6561516 Share on other sites More sharing options...
PN-Mad Posted October 3, 2012 Share Posted October 3, 2012 Uprev gives you control over the gearbox to some extent.... Yes it does. So to some extent you could actually replicate what the transgo shift kit is doing Physically, but tuning the ECU to do it electronically. I have done it to my car, however I also have the transgo shift kit. So I am unsure how good you could actually replicate the results of the shift kit in tuning the line pressures the ecu tells the gearbox ecu to run. However you also get the benifit of the tune. I don't know what the rwkw difference will be once you tune on a stock car, but you will get some benifit as well as losing the speed limiter, and setting the rev limiter to your desired limit. You may also chose to run upto 5 different ECU maps. What ecu have you been directed too? If its a piggyback, then run far far away. Chances are the person who is giving you advice has NFI about these cars. Uprev tuner is 700USD. Dyno tuning is on top of that- and I would charge more than 100-200 to do the job. Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6561552 Share on other sites More sharing options...
scotty nm35 Posted October 3, 2012 Share Posted October 3, 2012 Are those prices including the shift kit? Otherwise I need to put my prices up. lol. Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6561559 Share on other sites More sharing options...
Nightcrawler Posted October 3, 2012 Share Posted October 3, 2012 ^^^ Nope that price is not including the shift kit .... but remember a business workshop has significant thousands of dollars per week, every week, to pay for. Plus warranty if they stuff something up. In Adelaide we pay around $120 per hour for labour alone. Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6561629 Share on other sites More sharing options...
Jetwreck Posted October 3, 2012 Share Posted October 3, 2012 (edited) Are those prices including the shift kit? Otherwise I need to put my prices up. lol. I was thinking that to Scott.....if that's the price not including the kit then your getting ripped IMO. $500 fully fitted including the kit....not the oil. If your in Vic can't act Scott....NSW me.....other states ....ATM! Uprev ftw if you know what your doing with tuning. Edited October 3, 2012 by Jetwreck Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6561925 Share on other sites More sharing options...
PN-Mad Posted October 3, 2012 Share Posted October 3, 2012 $500 fully fitted including the kit....not the oil. If your in Vic contact Scott....NSW me.....other states ....ATM! Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6562016 Share on other sites More sharing options...
180 wanabe Posted October 3, 2012 Share Posted October 3, 2012 What oil are people using when having the kit fitted? I gave the local gearbox shop close to my work which a couple mates who have had commo boxes rebuilt recommend a call. They can supply the shift kit for $460 as opposed to the $300 ish via ebay etc The guy I spoke to said he had rebuilt a couple of boxes out of pathfinders which are the same RE5R05A box the 350z/V35 have. When I asked what oil he used he replied that he uses a synthetic oil he gets in bulk from Singapore which would cost me $7.5 per L and has had no issues with the RE5R05A boxes he has used it on..... This is a shop which has been around for 10+ years so id hope he is right Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6562095 Share on other sites More sharing options...
PN-Mad Posted October 3, 2012 Share Posted October 3, 2012 Nissan genuine. It's a good thing. Others have used the nylon fully synth with success. Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6562153 Share on other sites More sharing options...
scotty nm35 Posted October 3, 2012 Share Posted October 3, 2012 Mine was running generic Dextron III, although it has extra clutches installed in the baskets. I don't recommend it for a stock RE5. I use the Nulon synthetic usually as it's proven and easy to find. Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6562197 Share on other sites More sharing options...
T4NK Posted October 4, 2012 Share Posted October 4, 2012 I bought a shift kit off ebays for like $250-$300 i think it was at the time and had a full service on the box and kit fitter for $200 from my local auto transmission shop, they used the genuine matic J fluid also from Nissan the guy had a half full bottle of it as a door stop to keep his office door open Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6563433 Share on other sites More sharing options...
Jetwreck Posted October 4, 2012 Share Posted October 4, 2012 I bought a shift kit off ebays for like $250-$300 i think it was at the time and had a full service on the box and kit fitter for $200 from my local auto transmission shop, they used the genuine matic J fluid also from Nissan the guy had a half full bottle of it as a door stop to keep his office door open That's a win and a good price IMO! Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6563455 Share on other sites More sharing options...
T4NK Posted October 5, 2012 Share Posted October 5, 2012 I also forgot to mention the shops name lol, i used central coast automatics at westgosford if anyone is up newcastle/gosford and wants to get one done, they did mine so they know what they are doing. Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6565439 Share on other sites More sharing options...
bosco Posted October 7, 2012 Share Posted October 7, 2012 Are there transgo kit available for the v36 couple 5 speed? Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6568150 Share on other sites More sharing options...
scotty nm35 Posted October 7, 2012 Share Posted October 7, 2012 What is the gearbox code on the build plate? Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6568251 Share on other sites More sharing options...
bosco Posted October 8, 2012 Share Posted October 8, 2012 Re5r05a rc36 Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6568879 Share on other sites More sharing options...
scotty nm35 Posted October 8, 2012 Share Posted October 8, 2012 Same box, it will just have the computer built into the valve body so the HD2 kit's I have here will work. Where are you located? Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6569293 Share on other sites More sharing options...
bosco Posted October 9, 2012 Share Posted October 9, 2012 Sydney...what are the cost the hd2 and install atm...so I have a rough idea.. Link to comment https://www.sau.com.au/forums/topic/410691-ecu-vs-transgo-shift-kit/#findComment-6571308 Share on other sites More sharing options...
