Hi Everyone,
Had a minor ding in my 1995 R33 Nissan Skyline Gtst (Series 1) and need to get some cheap parts to get her back on the road.
I'm looking for the following parts:
1x Radiator
1x LH Headlight s1
1x RH Headlight s1
1x Bonnet s1 (in black would be ideal)
1x s1 Grill
1x Front Reo Bar
1x Thermo Fans
1x Engine fan
I had some quotes from mechanics to have it fixed but they are killing me on price so if anyone has some parts laying around let me know.
Cheers :thumbsup:
https://www.sau.com.au/forums/topic/410699-wtb-r33-s1-parts-need-asap/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
