I will try to get a pic of the actual lip ASAP. Going to call that guy tomorrrow or the day after. Probably will go down to him personally this weekend if the lip is done. I've not placed any orders yet, once he is ready I will update u guys about it and I will start to do a final head count early next week or even this weekend. Bear with me for the time being. BTW I might need to get a $50 deposit from those who wants to get it.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
