Whats peoples experiences with them? I seem to be hearing a fair amount of negative feedback towards them slipping. Need a half decent clutch ASAP. Rang NPC and they quoted me around $1000 for a cushioned button rated to 400rwkw and a flywheel for another $400.
I didn't really want to spend anymore than around $600-$800 on a clutch to hold 300rwkw.
Thanks.
https://www.sau.com.au/forums/topic/410705-exedy-clutches/
I toasted my Exedy clutch! (pics in build thread of you want lolz :laugh:)
Drove a 34 with NPC cushioned button, heavier pedal that the Exedy and bites harder etc... Not bad!
https://www.sau.com.au/forums/topic/410705-exedy-clutches/#findComment-6561741
NPC ftwbbq
Ask them for the 10" sprung button clutch and flywheel. Or if your being cheap, just get your flywheel shaved. $700 for the clutch.
Your getting sloppy man!
https://www.sau.com.au/forums/topic/410705-exedy-clutches/#findComment-6561756
I kind of wanted to keep good drivability because its a street car :/
Then go the cushioned button... Takes about 3 seconds to learn and is only $850 or something
https://www.sau.com.au/forums/topic/410705-exedy-clutches/#findComment-6561838
300rwkw? wtf do you need any special clutch for?
NSK-7056HDCB - Exedy Cushioned Button....off the shelf.....will hold 300rwkw. You don't need the flywheel.
Done
Yeah did me well.............. Not :P
https://www.sau.com.au/forums/topic/410705-exedy-clutches/#findComment-6561911
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
