Driving home tonight, the tacho, speedo, odo & everything in my instrument cluster went limp & died in my M35
They're all still lit up like they're supposed to (with the exception of the backlit odo & gear selection indicator) - the gauges have all just stopped functioning.
I've checked the fuses & can't see anything blown. Anyone got another suggestion?
:unsure:
https://www.sau.com.au/forums/topic/410714-instruments-dead-wtf/
Battery healthy? Able to check by chucking another one in?
I remember someone had an issue with the dash- car does funny things with a failing battery.
Other things could be can bus ground wiring or something equally wierd.
Pretty common apparently - happened to me a few times - initially just disconnected and reconnected the battery and they went ok for a while and then did it again and now they are fine. You could try taking the cluster out and waving a heat gun over the back of the board or get a small soldering iron and touch any dodgy looking ( I think "dry" is the term but I'm no sparky) joints.
I might try removing it & brightening up the plug connectors on Saturday & see what happens.
I'm just concerned its a computer problem of some description that won't ne resolved without burning the car to the ground...
Its not a computer problem its just a bad connection.
Turned out it was a blown fuse in the kick panel which had shut the alternator down.
Anyone got an English diagram of that fuse panel btw?
http://www.skylinesaustralia.com/forums/topic/309837-m35-fuse-box/page__p__5108325#entry5108325
Why did the fuse blow? Fuses don't blow for no reason. Now the fun begins!
