Hi,
I'll keep it simple,
CAR: 89 r32 gts4 (manual)
ENGINE: 95-97 stagea Rb25det (same/similar to s2 r33 rb25 I'm told)
Does anyone know if i can I get away with a s2 r33 engine wiring loom?
Or do I need specifically a 95-97 stagea loom?
First time rb conversion-ist so any help appreciated!
Many thanks
Pm or Text 0433046838
https://www.sau.com.au/forums/topic/410720-rb25det-95-97-stagea-engine-loom/
Either way I need to buy a Stagea s1 engine loom. Whether or not it needs to be spliced ill figure out when it's in my hot little hands.
Apparently should just plug in to my s1 stag ecu.
But who knows, either way I need a loom ASAP cheers
Ok here is what I would do.
  • I would not buy anything
  • I would use the rb20 harness
  • I would use the rb20 ecu
  • I would get a nistune board
  • I would be glad I did all the above
Now its not that easy but it is the Best solution and will give the best result. Do some research on the above because you are taking the wrong direction using a stagea harness & ecu.
