trans was opened up today
had a proper oil flush/replace 10,000km ago.... currently the fluid looks like red glitter paint. there is absolutely nothing left of the friction bands. And before you say it, NO i dont do burnouts. This is after normal use (by me). maybe the previous owners were not so kind...
so its in for a complete rebuild plus trans kit. $3000 approx..... and the shift kit is the cheapest bit.
this probably explains why my gearchanges have felt so slow and lethargic. unfortunately it gave no other warning signs, crunches or bangs, it just stopped working.
Not stressed about it. Love the car to bits
Edited by Deep Dish V35
factory spec bands, solenoids, etc. just the modified valve body. theyve been recommended as a bit of a nissan specialist who do in-house component mods.
the positive is, its just $1000 more than a replacement USED gearbox.... which i see as the better option
another note: have researched the re4r01b gearboxes, turns out the ones fitted to the VQ motor has different input/output shafts to the RB version, plus the bellhousing..... so you cant assume that all those gearboxes will fit
heres the diagnosis...
upon disassembly, the guys found that the first clutch drum had failed. the friction plates should be retained by a large circlip - that clip had popped out, allowing the friction plates to travel past their correct location and eventually shave themselves down to nothing. this generated extra heat and extra load within the trans. The trans fluid in the pan looked like glitter paint.
The 4 speed auto has only 5 friction plates in there, mine has now been upgraded to the turbo version 7 plate and drum assembly.
the servos have also been discarded and replaced with new larger units from a turbo assembly.
the solenoids have all been replaced for new
the torque converter has been stripped down and rebuilt with all new internals
and lastly, the valve body has had a custom upgrade (not transgo.... apparrently his are better)
all this , including R and R, and a weeks labour.... $3050
The trans guy say this is THE way to upgrade the RE4R01B 4 speed auto box. In my opinion it is too much money to spend on a V35 upgrade unless youve already broken it, however it works out to being only $500ish more than buying and installing a second hand box from a wrecker..... so definitely better for the money.
Will upload a vid to show the improvement next week
under instruction from the trans builder, i am not allowed to use full throttle until after 1000km and a re-check... so here is a short clip of about half throttle from standing start. thanks to my back seat passenger ;)
http://img.photobucket.com/albums/v716/sc850/V35/29A00525-E317-4F2A-9661-AE7C61D1A149-5894-000007E3A7B0C254.mp4
First to second... is quite grabby. Probably too harsh for my liking... we'll see if it eases up after bedding in...
    • Looking for a S2 front grill for an R34 GT/GTT Doesn’t have to be in excellent condition as I’m looking to paint it. Would preferred if the clips were around.    The $500 this marketplace guy is asking sounds ridiculous in my opinion.
    • Nah, just take the other one off too
    • A mini mini-gun.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
