[Qld] Big Garage Clearout. Lots Of 25/6 Parts
Hey SA,
Have a collection of parts from unfinished projects and left over parts from upgrades because of the damn need for more power :P
Prices are negotiable to fair offers. No swaps and no tyre kickers please.
pickup is fine and can also organise postage (at buyers expense obviously)
Ph: 0459 292 375
- R34 RB25DET Gearbox Rebuilt 12,000K Ago has OS Giken Push Pull Converter for 33,32 Push Style Cluthes $1800 with PP Converter
Will Seperate $1400 For Box and $400 for PP Converter
RB26 Inlet Manifold Plenum with ITB's - $200
Garrett 2860-5 Turbo Kit with Tomei Expreme Manifolds and Tomei Dump Pipes - $3500
RB26 CAS Sensor - $200
OS Giken Clutch and Flywheel (twin plate rebuilt buy NPC 12,000K Ago) - $800
RB26 Head with Supertech Springs - $1500
Stock Rb26 Zaust Manifolds - $50
Edited by rb26me
PRICE DROP!!
Must go, Accepting reasonable offers!
RB26 Head with Supertech Springs - $1000
Turbo Kit (2860-5's, Tomei Manifolds, Tomei Dumps) - $3350
OS Giken Clutch and Flywheel - $700
CAS Sensor - $150
RB26 Stock Manifolds - $25
Edited by rb26me
 Share
    • I would never LS an R32 either. I do have truly evil thoughts about VK56s or the Toyo V12s out of New Zealand though. Very hard to justify for my daily....
    • Oh no. There's heaps. A whole lot of them are legitimately handling/installation problems. The material used in the L19 bolts is susceptible to hydrogen embrittlement and must be kept well oiled and not handled without gloves, etc etc. There have been many failures of these from people who didn't realise. There may also have been failures caused by conditions inside the engine (say, head gasket failures?) and people didn't realise that that was probably a death warrant. But that's the L19 material. The ARP 2000s are not made of the same stuff and are more forgiving. But from what I gather there have been occasions where the head has pulled off of one, and non-one can say that the installation was at fault (given good torque records), etc etc, but maybe just maybe the face of the rod shoulder where the bolt head sits wasn't actually perfectly square to the bore of the hole...and loaded up the head with a torque across it and.... ping! I've head stories of bolt heads being found in corners of workshops or in the bottom of sumps even without starting and running the engine! Trouble is, it is really hard to sort the true material failures from the handling/installation failures. It's worse than human medicine. You can only run the experiment once, and you can't run it backwards in time to look at the rod before it became a modern sculpture.
    • In my experience with maxspeed rods, it was not that the ARP rod bolts were "fake" but they are made under licence from ARP, rather than made directly by ARP. Not the same thing and quite likely to have more quality variations, let's be realistic. I haven't had any issues with mine.  I daresay look hard enough, there would be some failures of genuine ARP products too though? Even if very few.
    • Haha honestly the thought crossed my mind but skylines are so damn rare here someone would probably hang me 😂    I’ve had a few LS swapped cars (280zx and a foxbody mustang) so trying something a bit different this time
    • Not much info in that request..... If you have a VIN you could look up the factory part number here: https://www.amayama.com/en/genuine-catalogs/nissan
