Hi Guys,
We are about to launch Yellow Jackets Coil packs for the V35 and V36 models and we have just about finished testing them for production.
Traditionally, before I release them to the market, I like to get a few random SAU'ers on board to give my coils some "real-life" testing and I will need testers for each type.
Please post or PM me if you'd be interested. There's a free set of coils in it for any one who can help out. :)
:cheers:
PW
I don't mind chucking some on my car for you. ATM its a turbo'd VQ35de.
If you really want to give them hell, we can get a few M35 Stagea owners out there to try them- running upto 25psi, and higher under bonnet temps cause of the turbo too. VQ25det are the same coils afaik.
I have a stock 2005 350gt 6MT that is my daily, and does around 200km of city driving a week. If that suits your test requirements, I am happy to test.
Same body but different part number, they probably run a higher coil output voltage as I have never found the limits of the stock VQ25det coils.
I could in a few weeks. The issue is, they won't represent how these will work in most peoples VQ engines as I run much colder plugs, 5 times the cylinder pressure and e85.
Btw Alex, the VQ25dd awd gearbox I was having rebuilt has different (weaker) internals, I have to get mine rebuilt as it won't handle the power. More clutches = more boost. :)
Its called extreme product testing :P
Talk about never ending gearbox story.... I didn't even know you had a DD gearbox. Auto for drags, manual for track = WIN!
Ideally, I want to give these coils a hard time to see what they can handle.
Well if you are happy to throw a set this way I can test them at 30psi in a few weeks. :)
My car doesnt see a hell of a lot of action during the week but is driven hard almost every weekend to make up for it. Would be happy to give them a try if you like. How long would the test run for?
Here's another V36 owner who is happy to give them a go. I have a tendency to thrash the car often (which is why I insist on servicing the car myself every 5000km) so I hope I can be considered one of the extreme testers, for a naturally aspirated vehicle.
Thanks guys. I'll send some PMs out shortly.
Im kind of new to the V series skylines. Can any one confirm for me what other cars/engines are interchangeable with the V35 coil packs and also the V36 coil packs?
Thanks in advance.
V36 (2008-) and Z34 (370Z) use the same VQ37VHR engine although I believe the V36 sedans didn't get this engine until the 2009 model. Otherwise, up until then the V36 sedans got the V35 engine.
Edited by The Max
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
