Hi Guys,
We are about to launch Yellow Jackets Coil packs for the V35 and V36 models and we have just about finished testing them for production.
Traditionally, before I release them to the market, I like to get a few random SAU'ers on board to give my coils some "real-life" testing and I will need testers for each type.
Please post or PM me if you'd be interested. There's a free set of coils in it for any one who can help out. :)
:cheers:
PW
I don't mind chucking some on my car for you. ATM its a turbo'd VQ35de.
If you really want to give them hell, we can get a few M35 Stagea owners out there to try them- running upto 25psi, and higher under bonnet temps cause of the turbo too. VQ25det are the same coils afaik.
I have a stock 2005 350gt 6MT that is my daily, and does around 200km of city driving a week. If that suits your test requirements, I am happy to test.
Same body but different part number, they probably run a higher coil output voltage as I have never found the limits of the stock VQ25det coils.
I could in a few weeks. The issue is, they won't represent how these will work in most peoples VQ engines as I run much colder plugs, 5 times the cylinder pressure and e85.
Btw Alex, the VQ25dd awd gearbox I was having rebuilt has different (weaker) internals, I have to get mine rebuilt as it won't handle the power. More clutches = more boost. :)
Its called extreme product testing :P
Talk about never ending gearbox story.... I didn't even know you had a DD gearbox. Auto for drags, manual for track = WIN!
Ideally, I want to give these coils a hard time to see what they can handle.
Well if you are happy to throw a set this way I can test them at 30psi in a few weeks. :)
My car doesnt see a hell of a lot of action during the week but is driven hard almost every weekend to make up for it. Would be happy to give them a try if you like. How long would the test run for?
Here's another V36 owner who is happy to give them a go. I have a tendency to thrash the car often (which is why I insist on servicing the car myself every 5000km) so I hope I can be considered one of the extreme testers, for a naturally aspirated vehicle.
Thanks guys. I'll send some PMs out shortly.
Im kind of new to the V series skylines. Can any one confirm for me what other cars/engines are interchangeable with the V35 coil packs and also the V36 coil packs?
Thanks in advance.
V36 (2008-) and Z34 (370Z) use the same VQ37VHR engine although I believe the V36 sedans didn't get this engine until the 2009 model. Otherwise, up until then the V36 sedans got the V35 engine.
Edited by The Max
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
    • They definately are coming back around, so many GTRs coming through again with them.
    • Besides which. If you have a Haltech waiting - don't waste your time and effort and money trying to get the boost sensor. Just f**k the stock ECU off and put the Haltech in. Then you won't need the boost sensor.
