Thanks guys.
This is what I have so far:
VQ35 VQ35DE (03-06)
SKYLINE (03-06): PV35/CPV35
INFINITY G35
STAGEA : PM35/PNM35
FAIRLADY Z / 350Z (03-06): Z33/HZ33
FUGA : PY50/PNY50/Y50
VQ35HR & VQ35DE 07-UP (does any one know what year these finish?)
SKYLINE : PV36/V36/NV36
TEANA : PJ32/J32
MURANO : PZ51/PNZ51
FAIRLADY Z : Z33/HZ33
How about the 2.5 models? Which coils suit these? Are the above year models correct for the models listed?
V36 (2008-) and Z34 (370Z) use the same VQ37VHR engine although I believe the V36 sedans didn't get this engine until the 2009 model. Otherwise, up until then the V36 sedans got the V35 engine.
So the 350Z (07-08) uses the same coils as the Z34 (370Z)?
PM35 Stagea, Z33 350z, V35 Skyline, Y50 Fuga all use the same coil (22448-AL615).
From 2003-2012 this was superceded with the 22448-AL61C plug for VQ35de powered Stagea, Skyline and Fuga.
No mention of V36 or Z34, so I would imagine that they use a different coil.
ok. Ive done a bit more research and have compiled this list:
Yellow Jackets part# YJ-VQ35-S1 - (VQ25DD VQ30DD VQ35 VQ35DE 3.5L V6):
VQ35 VQ35DE 3.5L V6:
SKYLINE PV35/CPV35 (03-06)
SKYLINE V35 250GT/300GT VQ25DD/VQ30DD
SKYLINE V36 SEDAN (up to 2009)
INFINITI FX35 (03-08)
INFINITI G35 COUPE/SEDAN (03-07)
INFINITI M35 (06-08)
STAGEA : PM35/PNM35 (01-07)
M35 (06-07)
FAIRLADY Z / 350Z Z33/HZ33 (Includes roadster) - (03-06)
CEFIRO A33 (99-02)
CEDRIC/GLORIA (99-04)
LEOPARD Y33 (97-99)
CEDRIC Y34 (99-04)
GLORIA Y34 (99-04)
Yellow Jackets part# YJ-VQ35-S2 - (VQ35HR & VQ35DE 3.5L V6 / VQ37VHR 3.7L V6 / VR38DETT 3.8L V6):
R35 GTR VR38DETT (08-12)
SKYLINE PV36/V36/NV36
SKYLINE V36 sedans (2009-Up)INFINITI G35 COUPE/SEDAN (03-07)
INFINITI EX35 (08-Up)
TEANA PJ32/J32
MURANO PZ51/PNZ51
FAIRLADY Z Z33/HZ33 350Z (Includes Roadster) - (07-08)
FUGA PY50/PNY50/Y50
FX35 (09-Up)
M35 (08-09)
ALTIMA SEDAN (07-12)
ALTIMA COUPE (08-12)
MAXIMA (09-Up)
MURANO (09-Up).
V36 VQ37VHR (2008-Up)
Z34 (370Z) VQ37VHR
How does this look?
  • 4 weeks later...
M35 (06-07)
CEFIRO A33 (99-02)
LEOPARD Y33 (97-99)
CEDRIC Y34 (99-04)
GLORIA Y34 (99-04)
TEANA PJ32/J32
MURANO PZ51/PNZ51
FUGA PY50/PNY50/Y50
FX35 (09-Up)
M35 (08-09)
MAXIMA (09-Up)
MURANO (09-Up).
Z34 (370Z) VQ37VHR
How does this look?
Just a correction, the Skyline V36 Sedans have VQ35HR (PV36) and VQ37VHR (KV36) engines.
PV36 are from 2006-2008
not a V36, I have a 370z, same engine though so imagine this would make for a sufficient test subject, I drive a minimum of 500km a week with a mix of highway and town driving, and i cant resist going hard in it half the time :P
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
