  • Replies 76
how many litres are you calling a tank? the tank is 65L, but fuel light generally comes on with 10L to go. is the fuel light coming on before you fill up?
as i say in every fuel economy thread, unless you are running it until it runs out of fuel, using "a tank" as a measure for economy is stupid. given that people will all fill up at different points on the gauge, the economy you are getting compared to others will vary by a fair bit.
still worth taking note of how many litres went in, because if it has an aftermarket fuel pump then they sometimes don't sit as low as the stock pumps and can make you run out of fuel well before the fuel light has even come on.
check you don't have a leak in the cooler piping somewhere. it probably has a large leak somewhere which is making it leak a heap of boost and making it run rich.
do you have an aftermarket boost gauge? if so, where does it sit when you are just idling? should sit about -20 at idle if there is no leaks
I'm sorry that I'm not being very helpful with my problem. And I do and it does sit right on -20
I would give more details but I'm new to it all and don't understand it to well, it's just getting too overwhelming.
Edited by Ausdogga
Ok, sorry,
Ill start again, fuel Econ it up the shitter getting 277k per tank on 98,
It won't hold revs changing gears or it they drop quicker by braking, I do have shit on my black bar, and a backfire at times I'm guessing burning the exsess fuel from it running rich,can be very very unresponsive and almost stall at times if I take off slowly, when I boost at times it will go to 11 then drop to 8 or 9 when I have it set at 10. I think that's it. :/ apart from that its all stock only running 10 pound,
Edited by Ausdogga
how's your water temp? perhaps your thermostat is cactus, also is your water temp sensor plugged in?
There's a chance the car is always thinking it's cold and dumping in loads of fuel. Unplug the water temp sensor and see if there's a difference, I had this problem before when I forgot to plug back the water temp sensor when I pulled the injectors out of my fridge.
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
