I'm fitting an aftermarket computer and have the option of running a more modern air intake temperature sensor as oppose to the stock rb26 one that is slow and soaks up the heat of the intake manifold. I am also fitting an r34 intercooler which has a nice hole to mount the sensor on the end tank. Will this give accurate readings or will i need to mount it much closer to the intake manifold.
I can't see the intake manifold being the best place for that sensor (WTF were Nissan thinking?).
Anywhere between the cold side of the cooler (where you have circled) and before it hits the engine bay. That way it doesn't get warm from heatsoak.
could run 35 gtr afm's if your keeping afm's that is
as they have air temp sensors built in to them :)
Maybe so. But after the turbos heat the air, then the cooler cools the air, what is the actual temp
Of the incoming charge?
Makes sense to me. Closer to the chamber the better.
exactly, dumb suggestion that one was. Pretty sure he isn't using MAF based setup anyway.
If you use the gizzmo gasket on the plenum, the factory sensor spot apparently reads much better as you don't get the level of heat transfer.
remember reading someone testing that back a while ago. Still doesn't help the factory sensor is really slow though, but at least once caught up it was certainly lower and more realistic.
hook line sinker Nismoid head
Did I hear a stfu? Oh sorry that was me. The best place to mount that bitch is as close to the intake valve as possible. Passing air will take care of heat soak bitches. But mounting that shit in the port aint going to happen now is it bushies? Put it as close to your throttle body as possible. Right where your f**king blow off valve should be. Just after that bitch. That is about an inch. Gota keep that pressure in the cooler now dont we?! (more swearing and cursing)
Edited by Room42
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
