I'm fitting an aftermarket computer and have the option of running a more modern air intake temperature sensor as oppose to the stock rb26 one that is slow and soaks up the heat of the intake manifold. I am also fitting an r34 intercooler which has a nice hole to mount the sensor on the end tank. Will this give accurate readings or will i need to mount it much closer to the intake manifold.
I can't see the intake manifold being the best place for that sensor (WTF were Nissan thinking?).
Anywhere between the cold side of the cooler (where you have circled) and before it hits the engine bay. That way it doesn't get warm from heatsoak.
could run 35 gtr afm's if your keeping afm's that is
as they have air temp sensors built in to them :)
Maybe so. But after the turbos heat the air, then the cooler cools the air, what is the actual temp
Of the incoming charge?
Makes sense to me. Closer to the chamber the better.
exactly, dumb suggestion that one was. Pretty sure he isn't using MAF based setup anyway.
If you use the gizzmo gasket on the plenum, the factory sensor spot apparently reads much better as you don't get the level of heat transfer.
remember reading someone testing that back a while ago. Still doesn't help the factory sensor is really slow though, but at least once caught up it was certainly lower and more realistic.
hook line sinker Nismoid head
Did I hear a stfu? Oh sorry that was me. The best place to mount that bitch is as close to the intake valve as possible. Passing air will take care of heat soak bitches. But mounting that shit in the port aint going to happen now is it bushies? Put it as close to your throttle body as possible. Right where your f**king blow off valve should be. Just after that bitch. That is about an inch. Gota keep that pressure in the cooler now dont we?! (more swearing and cursing)
Edited by Room42
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
