How Loud Are Turbo's Supposed To Be In The Car?
Rancher
 Share
Another strange question from me.. I have googled, and found nothing that answered my question.
I still haven't assessed if I have a high flow or not. Doesn't matter. What a mate of mine did point out, is how loud my turbo is. You can hear the whistle (duh). But, inside the car, you can hear the turbo sucking in air seriously loud. Is this normal? Do others do this? Standard, high flowed? Etc? Is it gon' die?
I did spend the last 20min odd on youtoob, and couldn't find another boat owner with the same noise.
HALP thanks.
Being thinking about something similar..
Ive got a couple questions.. Without using pods what would make induction noise louder? and Would a metal intake kit with standard air box make the induction noise louder? I would love to get a pagani huayra sound in my car lol
It's all to do with the pod, and the type of pod. Some pods have more noise associated than others - whether its because of the level of filtration, or the actual construction metal vs plastic etc) who knows, not really a point anyone would probably care to look into.
Pod - lots induction noise
airbox/enclosed pod - less induction noise
GTRs make a bit more because of the side intake.
Take it to a shop that deals with these cars everyday and ask them to drive it. Any decent shop will be happy to take 5 minutes to tell you if it's normal or not. If its super loud it's probably not normal. A bit of noise is normal when you have a pod though. Better to be safe than sorry and what harm can it do to have it checked by a professional?
in my experience a poded R33 has mega induction noise. I originally had a K&N which was incredibly loud, I changed to a HKS shroom and the noise changed a lot. much quieter.
The stock RB25 turbo makes a silly amount of noise with a pod filter. In my old R32 it was by far the loudest, The Apexi AX53B70 made next to no noise and the 3076R made more of a whistle, but nothing seems to match the stocker for sounding like a vaccume cleaner! lol
Yeah i found the pod, split dump etc on my high flow was super spoolage! With a bit of Ztutututu just for Josh.............
The 3076 does spool loud followed by epic whistle and then lots of GAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATE :woot:
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
