GTX3076 with steel pipe and pod, incabin is a constant whistling/whining like a kettle that never stops boiling even off boost, a quiet air sucking noise, always hear stock turbo's doing that spooling noise, easy to pick them out.
Edited by SliverS2
You should hear the older GT 3037 56T lol......... Its like the kettle is launching for space :P
Have you heard the BW S300sx at full noise Dan?
Mine sounds awesome even at 18psi
OH OH OH, so the old girl is all tuned and stuff now, linky to results/pics, you going to the SAU nats ?, is it run in ?, lets go to the drags !!!!!!
Not yet. It was getting the surge tank put in while I was out there today. Not long though!!!
470 @ 26 psi is my bet!
SWEET
And I did see that perty surge tank, I was going to pinch it but people were looking, LOL.
Being thinking about something similar..
Ive got a couple questions.. Without using pods what would make induction noise louder? and Would a metal intake kit with standard air box make the induction noise louder? I would love to get a pagani huayra sound in my car lol
Yes. I have a standard airbox, but a metal intake pipe, I get a really loud induction sound.
Mark as soon as Pauls and mine are done we are all heading to the drags!!
And keep ya dirty engineer hands off my tank :D
I reckon your about right there Paul
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
