GTX3076 with steel pipe and pod, incabin is a constant whistling/whining like a kettle that never stops boiling even off boost, a quiet air sucking noise, always hear stock turbo's doing that spooling noise, easy to pick them out.
Edited by SliverS2
You should hear the older GT 3037 56T lol......... Its like the kettle is launching for space :P
Have you heard the BW S300sx at full noise Dan?
Mine sounds awesome even at 18psi
OH OH OH, so the old girl is all tuned and stuff now, linky to results/pics, you going to the SAU nats ?, is it run in ?, lets go to the drags !!!!!!
Not yet. It was getting the surge tank put in while I was out there today. Not long though!!!
470 @ 26 psi is my bet!
SWEET
And I did see that perty surge tank, I was going to pinch it but people were looking, LOL.
Being thinking about something similar..
Ive got a couple questions.. Without using pods what would make induction noise louder? and Would a metal intake kit with standard air box make the induction noise louder? I would love to get a pagani huayra sound in my car lol
Yes. I have a standard airbox, but a metal intake pipe, I get a really loud induction sound.
Mark as soon as Pauls and mine are done we are all heading to the drags!!
And keep ya dirty engineer hands off my tank :D
I reckon your about right there Paul
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
