iv had the trouble in my R33 of my ac switching on and the often (but not always) off again after only 5-10 secs of being on (this is in A/C on mode with 18 degrees selected so technically should run indefinately in warm weather as the interior isnt 18degrees before it switches off sometimes). Sometimes it doesnt even switch on.
THo there is no constant situation (like hot or cold ambient) where it runs, is intermittent or doesnt switch on in.
There is plenty of refridgerant as the view glass is nice n green when on and the air is nice and cold.
Iv run the diagnostic mode and no faults.
anybody know what might be the cause of this or experienced it?
otherwise can you access all of the cars sensors via a consult cable and program? im sure that one of the sensors must be shitty and so going outside its operating range quickly and then switching the AC off. Tho its problem doesnt show in diagnostic mode...
Anybody? (i cant go another summer without it working)
I've got the same problem sometimes also. A lot of on/off click clacks that dont seem to be related to temperature eg it will switch off when its hot but stay on when its cold. Its definitely electrical related. Putting new or more gas would just make the on states cool better.
I'm a bit pissed manufacturers dont allow control over an always on a/c state
For example you have 18 degrees and then pressing the down arrow again for temp sets it to "Cool" which is always on. That way we can take any sensors out of affecting anything.
I wonder if there is a way to modify anything to disable the sensors or report an always hot state.
yeah this is my rationale too- some sort of a mod to get it to just stay on when AC is selected.
if it isnt on Auto and its is selected at 18degrees with AC on then it should run indefinately. Which it does when working correctly (my other skyline did this fine).
I might get it this week and put it in diagnostic mode after running the AC as much as i can and then put it in diagnostic mode when it is playing up. Hopefully then the system or sensor that is problematic might show up...
Edited by jjman
ah.
cheers for that then.
Is that maybe a reason it is turning itself off that it thinks the core is already cool enough?
or conversely that it thinks the system is overheating?
otherwise do you have any idea what might be the most likely fault to cause this temperamental on-off behaviour (when the AC diagnostic mode indicates no faults...)
it seems to be a common enough problem that im sure someone has resolved it in the history of SAU...
Edited by jjman
Cutting out 5-10 secs after startup is typical of low gas usually.
The compressor will suck the suction line into a vacumn and pressure switch will cut out.
Try bridge switch and see if it continues.
Or bridge high pressure switch incase it has a blockage.
I meant bridge/bypass the switches. Low pressure switch should be in the compressor and high pressure is in the dryer (aluminium canister) near the radiator.
The days it works could possibly due to the vehicles heat pressurising what little gas is left enough to not cut out. Hard to say over the net.
Perhaps get a shop to put gauges on it and ensure there is enough pressure. If so then you can continue troubleshooting.
ah yep.
too easy, will do.
cheers for that mate.
  • 4 weeks later...
If its low on gas obviously there is a leak somewhere. Is it possible to introduce a leak by tugging on ac lines in the engine bay. If so anyone know how long it takes for the slowest leak to loose gas to a point the ac system doesn't cool whatever.
I had a car once that would loose gas every year and no one found the leak even with the dye in it. They wanted 3k to open up the dash. very anoying.
  • 1 month later...
jjman I have a similar problem on my S2 R33 gtst, but it lasts longer. All sensors say it is fine and temperatures being read are fine, but if it is a 35-40 degree day and I put the climate control on when driving it will blow cold for 5 min if on auto or full or up to 20 minutes if fan only on 1 or 2, but then revert to ambient temp air. I assume this is to do with a sensor being OK during diagnostic mode and then buggering up when actually being used.
Another thing I noticed and can't think of why is that the air stays cold for much longer if the car is idling, but if I take it for a drive it will go to warm quite a lot lot quicker. Again, I don't know if this is a sensor playing up. I've tried driving it around until it blows warm, then turning the car off and on and running diagnostics - still all looks normal (no faults, temps all ok).
I wonder if I can cheat the system by leaving the car on diagnostics - 42 (full cold) constantly while I'm driving around? Gonna give that a try today. Anyone got any thoughts?
Edited by Bloodnut
Sounds like its freezing up. Next time either try with fan on max and it will prob last longer. Or when it goes warm, turn the air con off but fan on max. After a minute shitloads of water will prob pour out the drain onto the ground as it melts. There will always be water dripping from the drain but if its freezing it will be excessive
Still chasing the problem of the a/c compressor not switching on at all. it will cool if bridged/bypassed at pressure sensor or at relays. The problem I am thinking it could be is a wiring stuff up in/around the relays, or a sensor I have missed. I have checked sun sensor(windscreen) cabin sensor(dash near steering wheel) outside sensor (at front of car) I have changed and checked the sensor that has the heat sink on it at the fan box (behind glove box). Is there another sensor I have missed? possible on the core under the dash or something. I don't want go and pull the dash apart more if there is not one there. And on the wiring side of the problem could the relays be possible wired wrong. with out a proper/complete wiring diagram I feel I have been running blind with the parts of diagram that are available. I feel I have checked this system over and over still no luck though. :(
Edited by a2z
Iv worked out with mine that the AC will actually start running quite well if i just leave it on (18 degrees, AC, 3/4 or full blow).
Initially it isnt too cold but it then seems to start blowing cooler and more consistently after a while and will get really cold after quite a while
No idea why...
Tho the air-con compressor was replaced just before i bought the car and i think it is an aftermarket unit or a non-R33 specific compressor. I wonder how this might be affecting things..?
Edited by jjman
I was talking to an auto electrician today and because the air con compressor does not even kick in he said there could be another control unit between the climate control module and the ecu and compressor. I even tried taking the ewcu out of the equation by bypassing it but no change. Does any one know if there is another control unit somewhere or something I'm forgetting to check??
  • 11 months later...
Ever get a fix to this a2z? Got the exact same aircon issues. A/c compressor won't cut in unless I bridge the aircon relay or bride two of the 4 wires on the pressure switch on the receiver drier. If I bridge the other two wires on the switch it powers the condenser fan relay.
Everything operates as it's ment to, aircon gets cold when bridged. it's just been re gassed with the correct amount of r134a. The idle increases as it's ment when switching the aircon switch on and off as the ficd relay powers up. there is no signal being sent to the aircon relay to switch the clutch in. Annoying!!
If you can get it to work by bypassing the pressure switch, then is it likely that your pressure switch is no good? They do stop the AC system running if the pressure is low to prevent damage to the compressor
  • 1 month later...
Hi guys.
A lot of you seem to be having the same problem as myself. That is, you have ruled out the basics being gas or issues raised in the climate controls diagnostics menu.
The culprit could be the thermister.
This is a temperature probe that monitors temperature of the internals of the a/c unit (the heater core) that is in the cabin behind the glove box.
If the temperature is too cold, it tells the a/c clutch to disengage so it doesnt freeze up. One of the symptoms if this part isnt working correctly, is a random on/off activity regardless of the state of your cars movement, weather, temperature settings, etc.
Nissan says they dont stock the part any more, (Nissan FAST part number is 27675X or 2765XA depending on your car) and with so many people having problems with their a/c, you wouldn't use a second hand one.
It is possible to install a generic thermister (around $50) in a new hole next to it and reuse existing wiring. The original clip has 3 wires in it, one for power and the other 2 are for the readings.
If you replace the original, you have to degas, open everything up, remove the 2 wires from inside the unit. If you instead add a new thermister next to the other, you just drill a tiny hole in the unit, and mount it inside the casing near the heater core. Then reuse existing wiring. As the case stays closed, no need to dismantle and degas/regas. Saves $200.
Others may have more experience in this topic and feedback or corrections are welcomed, including prices and stockists.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
