Hello sau, I have a few R32 gtst part I want to sell I'm located in Mulgrave Melbourne my contact number is 0468 394 411
1. Vertex side skirts x2 to suit a R32 gtst in good condition $150 ono or will swap for stock guards with a cash adjustment.
2. Vented wider front guards x2 to suit a R32 gtst in good condition $150 ono or will swap with a cash ajustment.
3. R32 gtst stock alloy guards x2 with dints and minor damage good for a track car $50.
4. R32 gtst rb20det stock ecu $60.
I have also got a few other bits and pieces, like a blow rb20det $100ono with stuffed rings, stock rb20det turbo $100, damage R32 fiber glass Gtr bar but can be fixed $50 make me a offer need to clean my shed out. I have more but will upload photo of every thing and see what else I have that I want to get rid of, negotiable on all prices :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
