My 2003 V35 Coupe has a noticeable delay when shifting from Reverse to Drive - wait, wait, wait, ok I'm ready now:). It doesn't always do this, but often enough to be a pain. Is this "normal", or should I be worried? Shifting during normal driving seems fine.
Also is there an easy way to ID the trans fluid? The fluid in mine doesn't look burnt or dirty, nor does it smell burnt. It is a light brown / honey colour, not red as I would expect from "normal" (Dexron) trans fluid. I believe it was replaced around 4,000 km ago, but I don't really trust that. What colour is the Nissan Matic J fluid, and the Nulon Synthetic?
Thanks
It's red of course, just like any trans fluid. It would be nearly impossible to ID what is currently in your sump but it can go brown quickly.
I wonder if the shift linkage needs adjustment, or the switch on the valve body... What state are you in?
Scotty - I'm in SA. The fluid isn't a dark brown, more a light honey colour, almost clear. Looking at the colour I doubt that it was ever red. Are you saying that both the Nissan & Nulon fluids are red when new?
Edited by GeeDod
As far as I know, I have never used the matic J, only the Nulon recently but every auto fluid on the shelf I have used was red. CVT would obviously be different.
I doubt the fluid is causing the delay into reverse, more likely something blocked in the valve body.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
