Hi there,
I have done a bit of searching but still thought that I would post here. I have a non premium 2004 Skyline & wanted to swap out the factory non- Bose speakers for something better. Am I right to presume that the speaker sizes for the non premium & the premium are the same? Front are 6.5" & rear 5.25" according to what I read on here. Correct me if I am wrong.
I have an Alpine head unit an new model a ICS-X8 I don't know a great deal about speakers in cars but I have been pointed towards the X series Alpine speakers. Can anyone advise if these are good or if I should look at something better? I know that it comes down to budget. I usually just buy the best but I am not that into car audio that I want to go nuts.
I would also like to know where is a good place to purchase in Adelaide & also to get them fitted. Are they hard to install? I am not that handy but if there is someone that can be recommend then that would be appreciated.
https://www.sau.com.au/forums/topic/410831-speakers-for-the-v35/
  • 5 months later...
Hey Bud,
I had a 350Gt and now have upgraded to a 370Gt and now have all these parts left.
I replaced the front speakers with alpine type R, which are top of the line speaker for Alpine, sounded awesome on the stock unit clear and bassy. It was only in my car for 8months then I decided to upgrade. RRP was 370 i think
if your interested on them they are in a box, close to brand new and I have the speaker MDF wooden spacers aswell.
I also have a Sway bar, Injen CIA, Motordyne plenum spacer, Black out side indicators, if your interested PM me?
Will post up pics on the parts soon
Cheers,
Jose
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
