What Music Are You Listening To?
Do you mean not a limit to a certain power level? Surely if an injector is 100% open, there will be a limit to how much fuel can flow through it. -
Its a VR30DDTT, LPFP is Low pressure fuel tank (in pump) and HPFP is High pressure / mechanical fuel pump. Injector size doesn't seem to be a limit on that engine
So you want to run e30 on stock injectors and fuel pump? -
Well, as long as you have the flex fuel kit you can use any ethanol mix. Also FYI the pump e85 varies between about e70 and e85 across winter and summer from most pumps
