  • Replies 3.5k
11 hours ago, GTSBoy said:
This morning was Kingswood's Microscopic Wars. It is the album's 10 year anniversary this year and we went to see them play the whole album as a special show a couple of months back. Was pretty spectacular.
That sounds pretty good.
I saw them play at work, once.
They were pretty good.
One of the band members was slightly inebriated and throw a t-shirt merch box into the crowd.
After their set, they tried to recoup the t-shirts or payment. Was funny and sad at the same time.
That sort of chaos is totally on brand for them. My girls are friends with them and have seen some total chaos at various festivals and shows.
  • 3 weeks later...
  • 4 weeks later...
