I was first wondering why you'd want to put a turbo from a Territory in your Skyline...
They run a GT35/40R - so would go pretty good on an RB25! Acknowledge he has an RB26DETT from the looks of the sig pic....but I had one on an Rb30ET and it ran a 12.6
My vote is on an e53 X5 3.0D - although in your price range you'd be looking at one with around 200km on it.
The petrol V8's are a beast - you could pick up a 4.4is or a 4.6is (which is a stroked Alpina motor :3some: ) and fit a tow kit and an X-pipe in the exhaust and you'd have one sweet cruiser that sounds mental and does a 1-100 in 6.1 seconds. Bonus is they have self levelling rear air bags, so great for towing. They will drink, approximately 20L/100km, but because they're thirstier than the diesels you can pick them up for the 25k mark with much less km's than a diesel generally, and then you can get a liquid vapour injection kit fitted for 5k which rounds you out to 30k nicely.
I know all this cos i've been looking at buying one recently and spent hours upon hours trying to make the numbers stack up but in the end i do too much commuting to justify the running costs. PM me if you're interested in this idea though because I can tell you what to look out for when inspecting.
http://www.carsales.com.au/private/details/bmw-x5-2002-13440699?base=1216&vertical=Car&cr=11&eapi=2&__N=1246+1247+1252+1282+1216+246&num=15&silo=Stock&Range=Price:Min,30000~0.5&items=[Make:BMW,Model:X5,BaseEnabledBadge:IS STEPTRONIC]&sort=default
Edited by SMOKEYC34
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
