Nissan 180sx S13 NON TURBO SR20DE Engine just had full service completed
1993 model with 62***kms or so, Digital climate control
SR20DE Conversion Non turbo engine running well
Ppg Painted Rocker cover with Cinnamon brown and purple pearl through
5 speed manual with good original gearbox, clutch feels good
R200 big nose upgraded LSD
New Engine oil, oil filter, Gearbox oil, recently changed diff oil,
Aftermarket alarm with remote
HKS Mushroom Air filter + New HKS Replacement foam just added
S14 Intake pipe upgrade over s13 with bigger air resonator
NGK new spark plugs
SPLITFIRE aftermarket ignition leads
Nissan NISMO 7 layer steel exhaust manifold gasket
S13 standard exhaust with hi flow cat and resonator swapped over with a straight pipe (good tune not loud)
Lowered suspension
front BILSTEIN shocks with HKS Springs
Rear KYB adjustable damping Shocks with KYB Springs
Aftermarket adjustable rear Toe arms
Rear solid cradle bushes in stealth black
Turbo front and rear brakes with front aftermarket cross drilled discs
Stock SR20 alloy wheels legal and subtle
Tinted rear windows on hatch and quarters
Aftermarket sports gearknob
aftermarket gear leather boot
Aftermarket 3 gauges Boost/Vacuum Water temperature and Oil pressure (just needs sender hooking up , sender supplied)
Stock standard steering wheel, horn works electricals work
A/C removed completely was never used and needed gassing, now looks clean and saves weight
CD player there but hasnt been hooked up at all
Silvia S13 Convertible Front matching seats
Sleepy eye headlight controller
What needs doing:
Rear tail lights have to have plugs put on them to plug them in as it used to have ugly aftermarket rear tail lights, simple minor job might do it if I get some spare time
Has few holes in boot from previous wing which is now gone
some scratches here and there and tiny dents
For the price and Being a hard to find non turbo later model 180sx with minimal kms on clock these are very minor things. Selling as is unregistered and no Roady, has many aftermarket extras which would make it a great car to drive and minimal $ spent on it over the next few years
Have no Space or use for it any more $5000 as is , pickup Southside Brisbane , please ring or text me on 0433377325 Thanks
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
