Nissan 180sx S13 NON TURBO SR20DE Engine just had full service completed
1993 model with 62***kms or so, Digital climate control
SR20DE Conversion Non turbo engine running well
Ppg Painted Rocker cover with Cinnamon brown and purple pearl through
5 speed manual with good original gearbox, clutch feels good
R200 big nose upgraded LSD
New Engine oil, oil filter, Gearbox oil, recently changed diff oil,
Aftermarket alarm with remote
HKS Mushroom Air filter + New HKS Replacement foam just added
S14 Intake pipe upgrade over s13 with bigger air resonator
NGK new spark plugs
SPLITFIRE aftermarket ignition leads
Nissan NISMO 7 layer steel exhaust manifold gasket
S13 standard exhaust with hi flow cat and resonator swapped over with a straight pipe (good tune not loud)
Lowered suspension
front BILSTEIN shocks with HKS Springs
Rear KYB adjustable damping Shocks with KYB Springs
Aftermarket adjustable rear Toe arms
Rear solid cradle bushes in stealth black
Turbo front and rear brakes with front aftermarket cross drilled discs
Stock SR20 alloy wheels legal and subtle
Tinted rear windows on hatch and quarters
Aftermarket sports gearknob
aftermarket gear leather boot
Aftermarket 3 gauges Boost/Vacuum Water temperature and Oil pressure (just needs sender hooking up , sender supplied)
Stock standard steering wheel, horn works electricals work
A/C removed completely was never used and needed gassing, now looks clean and saves weight
CD player there but hasnt been hooked up at all
Silvia S13 Convertible Front matching seats
Sleepy eye headlight controller
What needs doing:
Rear tail lights have to have plugs put on them to plug them in as it used to have ugly aftermarket rear tail lights, simple minor job might do it if I get some spare time
Has few holes in boot from previous wing which is now gone
some scratches here and there and tiny dents
For the price and Being a hard to find non turbo later model 180sx with minimal kms on clock these are very minor things. Selling as is unregistered and no Roady, has many aftermarket extras which would make it a great car to drive and minimal $ spent on it over the next few years
Have no Space or use for it any more $5000 as is , pickup Southside Brisbane , please ring or text me on 0433377325 Thanks
