r33 gtst dedsxe home and away
undefinedundefined yellow gold pearl kit 18s carbon bonnet mirrors wing yellow racing seats custom boot .4*tvs one dash one boot two in visers in dash dvd player gauges boost and turbo timer .custom cooler also brand new gt35r turbo with custom exhaust manifold external waste gate 245kw at wheels on 14psi so far12 month rego was put on 14th this month spent over 55 thou open to offers .selling to buy house :P
Guest RedLineGTR
Post some images if you can?? Also make sure you read the rules you need to post up a price otherwise this thread will be closed.
Cheers Rob
the plates go with the car and how do i put photos on hear .I am askin 33000 anyone serious PM me with details where i can send photos to
Can help you there as I already have two views of the car which I photographed at the Mingara Skyline show and shine. Suggest you come back to me on this, drop into my office and I will upload these for you for nothing (or maybe a six pack! Johnny B (Clique Photography 0408792981)
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
