^^^ Takes skill to mask glass bonnets with vents and stuff. Pain the ASS you have to find the right opacities for the rest of them and then the bonnet/vents etc.. but looks good when done well!
Interiors are WAH WAH. But once you get them nailed they are a bit easier. They're never the same i find.
Matt - What's up with the background on that vertical shot of the rex? Did a ferry come and then go? The light trails look really OOF and the colours as well but not bokeh like, hard to explain!
THanks Jay, Loving that rainbow of garbage! Who else would stop to shoot that!? Love your eye for a shot!
Kory, A ferry was going past. of course it's soft, think about how it would be rocking on the water over a minute :) up down, side side!!!
I cleaned up this lambo shot so I could use it as my wallpaper.
If your into that sort of thing you can find the HIGH RES HERE
Edited by MaTBoY
Yeah I thought it was a ferry, but i meant the buildings in the background as well. I assumed because a ferry was there but it ghosted and made it look all weird kind of look.
Still a rad photo.
yeah sidd, just merged in photoshop after being taken with this...
cost $7 for the aluminium offcut and then a few minutes drilling/filing. probably the best $7 i ever spent on camera gear :D
wont spam the thread, but the last 10 or so panos in this set were taken using this. makes everything line up a lot better than when taken by hand. still doesnt compare to an iphone5 tho, i cant afford the pro tools :P
Edited by Jay019
not really an october pic (its from july 2010) but ive only just got around to looking through them so thought i might post just one.
yo, i think you dropped something
Edited by Jay019
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
