Hi guys
This weekend I went to tint my windows on v35 coupe and the guy said I need to find a way to get the windows to stay up permanently when I close the door ( when you open the door it goes down a tiny bit, and then up again when you close it).
Is there a fuse somewhere where I can take out to stop the window from going down that tiny little bit? For those of you that have tinted your windows before What did you do to overcome this problem?
Cheers
Edited by =CPV35=
There's a screw (on the car not the on door) which disables window up and down feature. Use a screw driver loosen it will disable and tighten it enable it
Edited by jbenj
