Hey all,
So have a GT3076 internal gate on my r34 GTT.
I made the switch from external to internal for a more stock look :/
SO boost creep...
I have a full 3 1/2 exhaust with no cat, bell mouth dump.
12 PSI actuator, and reaches that then climbs to around 16- 17.
With my current set up the level of boost im ok with, but my question is is 16-17 the limit of creep?
Or if i raise the boost level to say 14, will it then proceed to creep 18-19?
My end result is wanting to reach and hold 16.
Im hoping to not have to port the gate, but im thinking that i will have to.
Thanks in advance.
https://www.sau.com.au/forums/topic/410898-boost-creep-gt3076/
  • Replies 66
Posted Images
hey guys at the moment i am relying on the actuator. there is no point trying to control the peak of boost creep with a controller.
The gate is the issue, its not bypassing the gas quick enough.
But what i want to know is will the creep increase if i increase the boost with a controller?
No it shouldn't.
The volume of gas shouldn't change so it should just spike to the same level
Some 3076's have perfect boost control.
But this is the 2nd one ive heard that creeps in 2weeks. Havent seen it with my own eyes tho.
What actuator are u running?
Have u tried applying regulated compressed air to the actuator to ensure the wastegate flap is opening 100% in its throw?
Its possible the actuator is incorrect
when i was considering internal wastegate, im pretty sure MTQ said there was two different types of housing, one was suited to lower power and had a different size flapper, somthing to that effect..
dont know if thats your issue but could be.. i also recall Mafia mentioning about the different housings and the wastegates being different.
Edited by SliverS2
Its a garrett 12 psi actuator.
I checked it with compressed air, and it starts to crack around 10psi, but didn't open very far.
how far are they supposed to open?
And Yeh its a .63.
Any ideas if porting the gate will help?
If so is there anywhere i can get a bigger flapper from?
And Yeh its a .63.
They are supposed to keep opening as you pump more pressure in. You should almost get 90 degrees on the flapper
Normally the higher the engine revs the greater the amount of boost creep. I see that often. The only way out of it is to mill out the wastegate port and replace the original gate with one with larger OD.
Thats my rear housing ^^^^^^^^
ok guys i have a gt3076 genuine garrett using a ford xr6 5 bolt style in a .82 and it had major boost creep i kno if you purchase it from garrett or gcg you can request a bigger flapper as i didnt know this till i got my turbo :)
this is a must do but make sure you measure the flapper and contact stao
will be fitting it this week hopefully it fixes my problem :)
Also ditch the garrett actuator and use the kingugawa internal wastegate mine was holding 15psi dead flat on my old gt3071 :)
Edited by jet2nv
Nice to know the Kando actuators work well. Is yours the CNC item jet2nv? I have one of those at home waiting to go on a mates car.
I also noticed it had provision for 2 ports.. I dont actually know how to hook that up yet but i might look into it for my own car.
  • 3 weeks later...
ok so a update fitted the turbo after having the larger flapper fitted and machined still OVERBOOSTS :(
im using a 1 bar actuator also used one of hypergears still hits the same boost 23psi
my next thoughts are maybe its the split dump pipe
any thoughts?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
