Driving car early this morning, stopped at servo, turned off, locked up. Came back, car started and turned lights on then it stalled. Now have no ignition, doesn't crank/click or prime fuel pump, no dash lights but still beeps when key is in ignition and door open, interior light working. Have changed all of the fuses under the dash (only one busted which was an accessory - the cigarette lighter one) and the ignition blade fuse under the bonnet. Main switch working, swapped one of the abs/sunroof long green clip type fuses into the ignition position and still nothing. Is there are relay or breaker somewhere that i cannot see? Any advice would be great as have had to leave it at a servo overnight.
Edited by omz180
https://www.sau.com.au/forums/topic/410929-ignition-issue-stagea-rsfour-1997/
Sounds like all the battery circuit stuff is working but the main ignition circuit has failed. Long shot but I actually had a very similar issue for a while and traced it to the main ignition harness connector on the back of the interior driver's-side fuse panel.
I confirmed the issue by manually manipulating the really thick wires going into the top of the fuse panel and watching the ignition-operated stuff (like the instrument cluster) flash on and off.
The main harness connector (smallish, thick wire going in, only one or two terminals I think very vague menmory). It was making a poor connection. I removed the fuse panel and sanded and manipulated the connector on the plug to make better contact and that fixed it.
pulled out interior fuse box, all relays getting power, accessories getting power but test light on ign wires no power.. im stumped, cant seem to find a breaker or anything hiding up in there.. so many wires and tape. Time to call in a professional! I think this is beyond me
Edited by omz180
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
