G,day, Im after some knowledgable info.
Car is a R33 GTST running M/T Street radials, with my "drag suspension" (stock shocks w/ standard height springs) installed in the rear the car has been raised about 50mm and has given me around 1 deg positive camber (roughly using a straight edge and calibrated eye).
As it is a IRS car would this be fine to get near a 0 deg camber when it squats on launch.
I know there is more to it than rough numbers but really all Im after is a good starting point and then start adjusting from there.
Thanks, Mark.
https://www.sau.com.au/forums/topic/410931-positive-camber-for-drags/
I remember a thread on this semi-recently, in the past 4 months for sure.
I've had a bit of a search, but can't remember where it was. Someone else was asking much the same question. I'll keep looking and see if i can find it, was a few posts on the topic but i think it was in the middle of another discussion :(
I found a few but all they said was to get to 0 deg camber on squat, not what you could start around, on a yank site there was talk of 0.5 positive but that was on drag specific shocks and springs on a new Camaro.
Its a pity but I assume that people are not to keen on giving up their "secret"alignment settings they most likely spent along time working out....
Mark, you need to figure out a method to measure how far your car is actually squatting on launch.
From there, strap the car down so the suspension is compressed down that far. I'd then set the car up to still have the MINUTEST touch of positive camber.
You should then be pretty darn close to 0 when you actually launch it. As you'll have more grip then you currently have, it'll squat the slightest bit further, and that previous minute amount of pos camber becomes 0 camber.
Where I am ATM, best 60ft was 2.1
Installed stock shocks with heavy duty standard height springs, measured camber which came to positive 0.75 deg, as my camber was set at 0.75 neg on my Bilstiens w/ low King springs it is a change of 1.5 deg.
Car was raised from 340 to 380 at the rear, 40mm more height so hopefully the Drag radials will not hit the guard now.
If this doesnt work Im going to replace the low King springs for the heavy duty springs in my Bilstien shocks and set the shocks at the heighest setting.
Trying to get the car set up for the drags by just replacing the struts so I can have my normal street/track struts and my drag struts as the only thing I need to change, I can see this not working well though and a couple of trips to the tyre shop for re/re alignments between drags and circuit work.
ATM my main concern is getting the car set up for the SAU NATS airport run, weather permitting Ive got 4 Wendsday night drag days to get my sorted on.
Hopefully my 60 ft gets better and I can drop my times.
RWDFTWBBQ
Just thinking about it, put it on a wheel aligner mark, pull the car down (Strapping the rear down only) until your tyres touch the guards. Then slowly release the straps until you're 30mm off the guards. Set camber to 0 degrees at this point.
You were previously squatting hard enough to touch the guards, you've now raised 40mm, so allow an extra 10mm for further squat.
See how you go.
a lot of this is going to depend on the front / rear coil over spring rates and how the shock holds / releases weight... if youre planning on playing with what you have then you will need to launch the f**k out of your car and make adjustments at both ends till you find a sweet spot for your set up till you cant go faster.. tyres will play a massive part too
^ yep, it's about how the actual shock behaves that you need to worry about more than this camber quest IMO.
Bilsteins in my two experiences with them, are not good for drag activities as they are quite hard and raising might not help all that much. If you go any higher the rear will be sitting even higher in the air and having the weight starting front heavy rather than at least even to transfer backwards.
My problem is that I purchased some R32 GTR rims with 255/50 16 M/T ET Streets which do not fit well inside the guards (I believe the cool kids call it hellaflush), when the tyre hook up it makes the outside edge of the guard hit the tyres, My conclusion to fix this for now (I will end up getting some 16 x 8 rims with a better offset) is to raise it up a bit to give it better clearance for now, I tried to overcome this initialy but fitting some standard shocks but although it got me to a better height the valving in the old stock shocks was arse.
Ive raised the front up one groove on the Bilstiens, which now has it at the heighest settings front and rear, I shall then lower the rear down one groove at a time over the next couple of weeks to try and find the sweet spot for the clearance I need.
ATM front is 345 and the rear (after some settling) is 370, as the Kings were progressive springs and the new ones are not so the squatting shouldnt be as aggressive due to the new springs not being as compliant in the first stage of compression..
The boat will go in for a wheel alignment on Monday to ensure Im on a level playing feel after all the playing around with the ride heights, Im going to get the camber set to 0.5 positive at the rear.
I will see how it goes on Wendsday night weather permitting.
Did a 11.6 at WSID, 0.3 faster than last time, best 60ft was 1.9, now its time to keep working on my RPM at launch to try and find the sweet spot, I never managed to find the right RPM tonight, 4000 wasnt enough but 4500 was to much.
Finding the happy medium is not such a easy process, for me anyway.
I did get to watch a S chassis 2ltr manual do a 9.? though, it was fast.
Didn't see you there last night.
Not sure on what method you used and I'm no expert but revs are one thing and how you release or slip the clutch is another. If you simply 'dump' the clutch at 4500rpm it will lead to wheelspin (in your case), but if you slip the clutch out it wont send all power straight to the wheels and allow a better take off. Just about practise really as its hard to get right.
I managed to get my 60 foot down from 2.4 first pass down to 1.8 on 15" 215 re-mould tyres on the same night (this was a few years back mind you).
1deg+ is a good thing. If you're running a street R33 GTST on 255 MT ET Street Radials with a 5-speed then you should be aiming for the high 1.5 - low 1.6sec 60ft region. What pressure do you have in the tyres?
I started at 17psi then went down 1 psi per run, best 60ft was at 14 psi, I went down to 12psi but my 60ft got worse, more likely my technique than the tyre pressure though..
Alot of my issues has to do with being consistant, trying to get my launch RPM, clutch slip, tyre pressures the same to get some usefull information is fairly tricky, with a heap more seat time and playing around with the settings should help me whittle my times down a bit by bit.
Thanks, Mark
Needs more Auto...
Thanks, Mark
Let me know next time you're heading out to race. If I'm around I'll poke my nose in and see if I can help.
Thanks mate, Im in the process of getting my Link ECU tuned up with launch control, hopefully that will make at least 1 thing easier, all I need to do is work on the other 300 things to do to get some good times.
I did manage a 1.604 on the 24th, most were around the 1.7 - 1.8 though.
Cheers, Mark
You need front shocks that are set up on a "90/10" ratio. I'm no expert on the matter but from what I understand the shocks draw out easily to transfer the weight to the rear wheels when launching. The shock then has a slow compression to help keep the weight on the back as you accelarate.
11.130 @ 130.45mph, 1.779 60ft
Camber was 0.5 deg positive with 0 toe
12 psi in the tyres
So far so good, only had 2 runs tonight as I blew a cooler hose near the turbo, it was to hot and to much bother to try and fix it there.
Next week Im hoping for even better.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
