Wrecking R32 Gtr (Stocker), Sydney!
  • Replies 148
Hi mate, do you have the boot trim flap that goes over where the stock jack is stored? Do you have an assortment of interior trim clips I can get off you?
was the tailshaft causing any vibration when the car was running? (like worn joints or out of balance) might consider taking that off you.
nah don't have the first two things, tailshaft- car wasn't running when i got it so don't really know
I'm after the 4 bolts that hold the gearbox crossmember up along with the 2 plates that go between these bolts and the bushes
bolts where flogged out when i pulled it from the car so no..
  • 3 weeks later...
  • 1 month later...
Rubber window seals that goes along the top of the door frames. More interested in passenger side but will take a pair ;)
Call me good looking I have it all
He mate have u got a bare shell by any chance if so can u please call me on 0432526472
Sorry mate they go to the scrap fast if not damaged
have you still got the gtr rear diff axles and hubs?
Yea got it all flick us a pm
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
