It all depends on what you think is important. R33s have electric HICAS, so there is no extra bullshit equipment (hydraulic solenoids and lines) to get rid of like there is on R32s. So the minimal approach of just fitting a bar on an R33 is enough to get rid of the part that you really really want to get rid of.
The problems are that;
  1. If you leave the tie rods and tie rod ends in place then you are leaving half the places where slop in the HICAS system happens. This is compulsory if you just fit a bar.
  2. Lockbars are not road legal. They are considered to be "modification of a steering system" and unless yours is signed off by an engineer it is defectable.
There are better locking systems that include collars to get rid of slop. There are better ones that do not use a bar at all, but bolt on extra brackets and replace the tie rods and ends with toe control arms akin to what you have on a non-HICAS subframe. This is what I would fit if I was going to just fit stuff on. But what I actually did to my R32 was replace the rear subframe with a non-HICAS one, pull out all the hydraulic crap. The rear of the car looks 100% factory, so even though I have "modified steering system" it doesn't look like it, so I will not likely get defected for it even with the most Nazi cop/inspector. My way cost a lot of money though, because I had to buy the subframe and having the whole back end of the car apart was seen as an opportunity to rebush EVERYTHING.
cheers
https://www.sau.com.au/forums/topic/410958-hicas-lockout/#findComment-6575434
GTSBoy nailed it, do it properly, too much slop in the ball joints.
Get a non-HICAS subframe from an S14, replace the balls joints in the knuckles with bushes (SuperPro SPF1638K) and run adjustable toe arms.
Edited by Akshunhiro
https://www.sau.com.au/forums/topic/410958-hicas-lockout/#findComment-6576547
cheers
hi mate thnx for the info only thing is on my island we dont have any laws limiting what mods we can do to the cars we run every single mod there is we run on the streets becuase the cops dnt even check and cant say anuthing because there aint no law against car mods in a short way to say everything is road legal here
how about if i trow a bar and get other tie rods and tie rod ends???
because to get parts down here is a pain in the ass!!
https://www.sau.com.au/forums/topic/410958-hicas-lockout/#findComment-6576671
Hey, I didn't see you were in the Carib. Cool.
Of course you can buy new tie rod ends (don't need to replace the rods themselves), but it's not worth it. If you're going to buy new rod ends, you might as well buy stuff to get rid of the rod ends. Something like this http://www.nengun.com/midori-seibi/hicas-canceller or this http://www.nengun.com/nagisa-auto/hicas-cancel-rod are smarter.
https://www.sau.com.au/forums/topic/410958-hicas-lockout/#findComment-6576748
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
